BDDTech
#1 Posted : Saturday, June 22, 2024 6:26:32 PM(UTC)
BDDTech
How can I make playlist as an input ?
I will use Mp4 and jpeg files and like to change stay time for stills.
For example:
1. File1.mp4
2. file2.jpeg (10sec)
3. file3.jpeg (5sec)
4. file4.mp4
I really need this as an input, not using the playlist function.
#2 Posted : Saturday, June 22, 2024 6:41:03 PM(UTC)
For example:
1. File1.mp4
4. file4.mp4
One can not , List can but can not set durations
https://forums.vmix.com/...--problem-with-jpeg--png
BDDTech
#3 Posted : Saturday, June 22, 2024 7:02:23 PM(UTC)
BDDTech
For example:
1. File1.mp4
4. file4.mp4
Not really what I want to hear, So I need External input to create playlist using video and Stills....
#4 Posted : Saturday, June 22, 2024 7:34:11 PM(UTC)
For example:
1. File1.mp4
4. file4.mp4
Any reason you dont want to use playlist ?
BDDTech
#5 Posted : Saturday, June 22, 2024 7:36:42 PM(UTC)
BDDTech
For example:
1. File1.mp4
4. file4.mp4
Yes, I use this ons big screens in stadion, Playlist for sponsors need to run when there is no other interaction. and this playlist has mp4 and jpeg.
#6 Posted : Saturday, June 22, 2024 8:41:22 PM(UTC)
For example:
1. File1.mp4
4. file4.mp4
Playout of a playlist go to output anyway ie the big screens ;-) . No need for it to be a separate input .
BDDTech
#7 Posted : Saturday, June 22, 2024 8:43:38 PM(UTC)
BDDTech
For example:
1. File1.mp4
4. file4.mp4
Yes I know that.. but i like to switch from Vmix using different inputs where a playlist is 1 of them
nikosman88
#8 Posted : Saturday, June 22, 2024 9:49:46 PM(UTC)
nikosman88
Greece
For example:
1. File1.mp4
4. file4.mp4
Hello. A way to do a mix between videos and images and work as you need,is to make a script that when the image is selected,make a pause/sleep as many time you need and then go to next item. A script or if you use bitfocus companion,you can make triggers to do what you need
mntechnogeek
#9 Posted : Saturday, August 10, 2024 8:22:03 AM(UTC)
mntechnogeek
Another way to approach it...if you choose to accept it...is to put all your stills and videos into either Powerpoint or Keynote. You can control timing and transitions quickly, and even export a video if you'd like. True, it's not an internal-to-vMix solution, but it has its benefits.
