How can I make playlist as an input ?
I will use Mp4 and jpeg files and like to change stay time for stills.
For example:
1. File1.mp4 2. file2.jpeg (10sec) 3. file3.jpeg (5sec) 4. file4.mp4
I really need this as an input, not using the playlist function.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png
Originally Posted by: doggy  Originally Posted by: BDDTech  How can I make playlist as an input ?
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png Not really what I want to hear, So I need External input to create playlist using video and Stills....
Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  How can I make playlist as an input ?
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png Not really what I want to hear, So I need External input to create playlist using video and Stills.... Any reason you dont want to use playlist ?
Originally Posted by: doggy  Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  How can I make playlist as an input ?
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png Not really what I want to hear, So I need External input to create playlist using video and Stills.... Any reason you dont want to use playlist ? Yes, I use this ons big screens in stadion, Playlist for sponsors need to run when there is no other interaction. and this playlist has mp4 and jpeg.
Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  How can I make playlist as an input ?
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png Not really what I want to hear, So I need External input to create playlist using video and Stills.... Any reason you dont want to use playlist ? Yes, I use this ons big screens in stadion, Playlist for sponsors need to run when there is no other interaction. and this playlist has mp4 and jpeg. Playout of a playlist go to output anyway ie the big screens ;-) . No need for it to be a separate input .
Originally Posted by: doggy  Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  Originally Posted by: doggy  Originally Posted by: BDDTech  How can I make playlist as an input ?
For example:
I really need this as an input, not using the playlist function. One can not , List can but can not set durations https://forums.vmix.com/...--problem-with-jpeg--png Not really what I want to hear, So I need External input to create playlist using video and Stills.... Any reason you dont want to use playlist ? Yes, I use this ons big screens in stadion, Playlist for sponsors need to run when there is no other interaction. and this playlist has mp4 and jpeg. Playout of a playlist go to output anyway ie the big screens ;-) Yes I know that.. but i like to switch from Vmix using different inputs where a playlist is 1 of them
For example:
I really need this as an input, not using the playlist function. Hello. A way to do a mix between videos and images and work as you need,is to make a script that when the image is selected,make a pause/sleep as many time you need and then go to next item. A script or if you use bitfocus companion,you can make triggers to do what you need
Joined: 8/9/2020(UTC) Posts: 12  Location: St. Paul, MN Was thanked: 1 time(s) in 1 post(s)
Another way to approach it...if you choose to accept it...is to put all your stills and videos into either Powerpoint or Keynote. You can control timing and transitions quickly, and even export a video if you'd like. True, it's not an internal-to-vMix solution, but it has its benefits.
