neato23
#1 Posted : Monday, April 29, 2024 4:39:47 AM(UTC)
neato23
Trying to give myself a bit of automation here.
My initial goal was to do this with central control.
So in my case we've got a few commercials. We'd like to advance through them playing one at a time. So if I've got a moment in the show I'd like to be able to press a single button and have the commercial play, then the next time I press the button the next commercial in the list plays. Easy.
Central control wasn't advancing to the next time. I suspect that's because of the below though.
In the list I've set a trigger oncompletion nextitem. This works until I hit the end of the list. Is there any way to have the list keep recycling, so if we've got 5 commercials, once 5 have played it starts back at the top of the list?
I thought auto first would accomplish this but that resets to the first in the list each time a video is played, so just plays the same one over and over again.
#2 Posted : Monday, April 29, 2024 5:27:23 AM(UTC)
What if you set the list to loop ? if that doesn't work a script could do it as one can read (and count) the items in the API XML
neato23
#3 Posted : Monday, April 29, 2024 9:05:41 AM(UTC)
neato23
loop just loops the video over and over again.
I suspected scripting might be able to do this, admittedly I'm not familiar with scripting vMix but it's on my list of things to get into. Fortunately,I do have quite a bit of a programming background.
dmwkr
#4 Posted : Monday, April 29, 2024 6:23:43 PM(UTC)
dmwkr
Start a script OnTransitionOut that
- checks current name of list item (A)
- goes to next item
- checks new name of list item (B)
- if A=B goes to first item
nikosman88
#5 Posted : Monday, April 29, 2024 7:40:40 PM(UTC)
nikosman88
Greece
Hello. There is allready a script that does this you need. https://forums.vmix.com/...t--Like-Array#post109783
Thanks to Doggy
