Joined: 12/5/2023(UTC) Posts: 15  Location: East Coast Thanks: 2 times
Trying to give myself a bit of automation here.
My initial goal was to do this with central control.
So in my case we've got a few commercials. We'd like to advance through them playing one at a time. So if I've got a moment in the show I'd like to be able to press a single button and have the commercial play, then the next time I press the button the next commercial in the list plays. Easy.
Central control wasn't advancing to the next time. I suspect that's because of the below though.
In the list I've set a trigger oncompletion nextitem. This works until I hit the end of the list. Is there any way to have the list keep recycling, so if we've got 5 commercials, once 5 have played it starts back at the top of the list?
I thought auto first would accomplish this but that resets to the first in the list each time a video is played, so just plays the same one over and over again.
I thought auto first would accomplish this but that resets to the first in the list each time a video is played, so just plays the same one over and over again. What if you set the list to loop ? if that doesn't work a script could do it as one can read (and count) the items in the API XML
loop just loops the video over and over again. I suspected scripting might be able to do this, admittedly I'm not familiar with scripting vMix but it's on my list of things to get into. Fortunately,I do have quite a bit of a programming background.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Start a script OnTransitionOut that
- checks current name of list item (A) - goes to next item - checks new name of list item (B) - if A=B goes to first item
loop just loops the video over and over again. I suspected scripting might be able to do this, admittedly I'm not familiar with scripting vMix but it's on my list of things to get into. Fortunately,I do have quite a bit of a programming background. Hello. There is allready a script that does this you need. https://forums.vmix.com/...t--Like-Array#post109783Thanks to Doggy
