How change Country name to country flag
Joined: 4/5/2024(UTC) Posts: 3  Location: Kaunas Thanks: 2 times
Maybe someone can help me. I take direct information from the xml file. I can't change it. I need the country information in that file to be converted to an image. For example, "Germany" should be changed to Germany flag.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: aremigijus  Maybe someone can help me. I take direct information from the xml file. I can't change it. I need the country information in that file to be converted to an image. For example, "Germany" should be changed to Germany flag. Checkout the vMix tutorial video on using datasources. Have an image name Germany.png or .jpg In the title data source connection format enter for example c://{0}.jpg ( location where the image resides) {0} Will be replaced with the data Germany
Originally Posted by: doggy  Originally Posted by: aremigijus  Maybe someone can help me. I take direct information from the xml file. I can't change it. I need the country information in that file to be converted to an image. For example, "Germany" should be changed to Germany flag. Checkout the vMix tutorial video on using datasources. Have an image name Germany.png or .jpg In the title data source connection format enter for example c://{0}.jpg ( location where the image resides) {0} Will be replaced with the data Germany I wrote the path to the picture. However, the result shows a link but no image :(
Originally Posted by: aremigijus  Originally Posted by: doggy  Originally Posted by: aremigijus  Maybe someone can help me. I take direct information from the xml file. I can't change it. I need the country information in that file to be converted to an image. For example, "Germany" should be changed to Germany flag. Checkout the vMix tutorial video on using datasources. Have an image name Germany.png or .jpg In the title data source connection format enter for example c://{0}.jpg ( location where the image resides) {0} Will be replaced with the data Germany I wrote the path to the picture. However, the result shows a link but no image :( Sure it's and image placeholder and not a textblock in your title you are trying to set and set from a datasource ? I use country codes, same difference ;-)  Screenshot 2024-04-14 173936.jpg (75kb) downloaded 4 time(s).
Thank you very much. Everything works!
