aremigijus
#1 Posted : Sunday, April 14, 2024 7:44:15 PM(UTC)
aremigijus
Lithuania
Maybe someone can help me. I take direct information from the xml file. I can't change it. I need the country information in that file to be converted to an image. For example, "Germany" should be changed to Germany flag.
#2 Posted : Sunday, April 14, 2024 9:57:15 PM(UTC)
Checkout the vMix tutorial video on using datasources.
In the title data source connection format enter for example c://{0}.jpg ( location where the image resides)
{0} Will be replaced with the data Germany
aremigijus on 4/14/2024(UTC)
aremigijus
#3 Posted : Sunday, April 14, 2024 11:19:34 PM(UTC)
aremigijus
Lithuania
I wrote the path to the picture. However, the result shows a link but no image :(
#4 Posted : Monday, April 15, 2024 1:13:48 AM(UTC)
Sure it's and image placeholder and not a textblock in your title you are trying to set and set from a datasource ?
I use country codes, same difference ;-)
Screenshot 2024-04-14 173936.jpg (75kb) downloaded 4 time(s).
aremigijus on 4/15/2024(UTC)
aremigijus
#5 Posted : Monday, April 15, 2024 3:39:38 AM(UTC)
aremigijus
Lithuania
Thank you very much. Everything works!
