2 Pages<12
sinc747
#21 Posted : Tuesday, April 9, 2024 7:04:33 AM(UTC)
sinc747
Originally Posted by: mavik Go to Quoted Post
If vMixCall doesn't work for you, I can recommend two other options.
Zoom
MS Teams
I have been working successfully with Teams as this is used by almost every corporation. The Teams meeting is the greenroom where all speakers join and talk. Enable NDI/SDI out and you can take the upcoming 4 speaker out via NDI with isolated audio. Epiphan offers this functionality over SRT out in the cloud if you don't have a Teams environment. In vMix I have multiple mixes going for the different targets. Live, Greenroom, Presenter confidence monitors, Attendee Screens in the room or whatever you need. With NDI webcam you can pick up these feeds with different computers in the network to split the load.
Zoom is integrated these days and should work similar to a vMixCall and makes it even easier for zoom meetings.
Have you tried that?
Since Zoom is now built into vMix, along with vMix Call or course, it does make sense for vMix to implement its own solution that solves all of the audio issues that new and intermediate vMix users may encounter.
A new Green Room Feature would also attract new users that are looking for a more off-the-shelf solution while staying in the vMix ecosystem.
- Tom
sinc747
#22 Posted : Tuesday, April 9, 2024 7:09:36 AM(UTC)
sinc747
Originally Posted by: spinfold Go to Quoted Post
While it's only limited to the 8 vMixCalls available, I have setup a system where the 8 can be individually put into a greenroom (where they can freely chat with others placed there) or put live (where they hear mix minus). This involves quite a lot of audio changes for each switch, but it works and is very flexible.
You are to be commended for figuring out how to set up your own greenroom.
But what if you needed to implement this in vMix on a different PC with a different preset. Imagine all vMix inputs are different sources, different vMix Call passwords, different audio source.
All of you hard work setting up your greenroom on PC #1 does not easily port over to PC #2. Especially if you are new to vMix.
- Tom
spinfold
#23 Posted : Wednesday, April 10, 2024 10:25:49 PM(UTC)
spinfold
Was thanked: 14 time(s) in 14 post(s)
- Tom
In our case, we have a master vMix and Companion save file which does everything we could ever want to do for a production and we then don't use the functions we don't need, rather than building a show specific to the production. This means all the complicated stuff is tested and all we need to do is change things like colours, backgrounds and layouts to match the client branding. The "blank" version (ie without client branding) is about 110 vMix inputs and about 25 Companion pages. Copy those across to another PC and you're good to go.
But, ultimately, for our green room we need two dedicated audio buses (one for green room, one for OnAir) and that's it. The cleverness comes in the switching between modes, which is done via a Companion button press per guest.
Would be happy to share the exact methodology if you're interested, but I'm now away from the office for a week!
spinfold
#24 Posted : Thursday, April 11, 2024 5:17:34 AM(UTC)
spinfold
- Tom
Here's the "from memory" version - will double check the exact setup when I'm back in the studio next week and correct/add as necessary.
(PS - I did say this was complex, no it's not for the faint hearted novices!)
VMIX AUDIO SETUP
Code:
- Bus A = OnAir
- Bus G = GreenRoom
- All vCalls routed to Bus A, and NOT to Master
- Bus A routed to Master
COMPANION BUTTON TO PUT CALL 1 TO GREEN ROOM
Code:
- Actions:
--- Turn off automix for vCall1
--- Turn on audio for vCall1
--- Turn off Bus A for vCall1
--- Turn on Bus G for vCall1
--- Set vCall1 audio return to Bus G
--- (Optionally, change vCall1 video return to a different output)
- Feedback:
--- If vCall1 is routed to Bus G, light up
COMPANION BUTTON TO PUT CALL 1 TO LIVE
Code:
- Actions:
--- Turn on automix for vCall1
--- Turn off Bus G for vCall1
--- Turn on Bus A for vCall1
--- Set vCall1 audio return to Bus A
--- (Optionally, set vCall1 video return to a different output)
- Feedback:
--- If vCall1 is routed to Bus A, light up
You'll notice that on the way back into live, we don't put the audio live again (despite forcing it on when going into green room). So, you'll need to put them back on air another way - by cutting them to line again and letting automix do its thing.
Copy those two buttons to work for all 8 vCallers, and you're done.
You can also setup a button which routes a microphone on and off Bus G, so that a producer can talk to anyone else in green room.
If you want to add the ability for interruptible talkback on top of this, there are two ways.
Without using another bus:
Either use the GR/Live buttons you've setup above to put the guest into green room, talk via the mic routed to Bus G, then push them back to live. Or, have separate buttons which allows the mic to temporarily go to Bus G, and the caller's audio return to be Bus G, then reset it/put caller return back to Bus A on release of the button. For extra cleverness you could work out whether they need to go back to Bus A or G upon release (ie which mode they were in before you started talking to them) by using Companion's custom variables. This method does mean that everyone in the green room will also hear the producer, and the guest would also hear a snatch of any green room conversation happening at the time, but doesn't tie up another bus.
A cleaner way, but which does need an extra bus spare, is to setup say Bus C. The producer's microphone would be constantly routed to Bus C, which is not routed to anywhere else so can't be heard on air. When you want to speak to someone, simply set their audio return to be Bus C. You can use Companion custom variables in the same way to return them to Bus A or G upon button release.
If you have VTs, other live sources, music, etc which you want your guests to hear, these should also be routed to Bus A and routed OFF Master. Otherwise, when the guests are in OnAir mode, they will only hear each other. MixMinus will still work so no danger of them hearing themselves.
Hope all this makes sense.
sinc747
#25 Posted : Saturday, April 13, 2024 12:52:48 PM(UTC)
sinc747
VMIX AUDIO SETUP
Code:
- Bus A = OnAir
- Bus G = GreenRoom
Code:
- Actions:
--- Turn off audio for vCall1
- Feedback:
Code:
- Actions:
- Feedback:
Impressive for sure. I've worked up something similar but simpler. But I feel for those just getting into vMix and wanting to make use of vMix Call and Zoom integration. Your work (above) is a bridge too far for most.
- Tom
Nick
#26 Posted : Thursday, April 25, 2024 12:07:43 PM(UTC)
Nick
I would like vMix to offer a greenroom for vMix Callers and other guest so I can run a pre-show without my viewers accidentally hearing or seeing our setup process.
sinc747
#27 Posted : Thursday, January 30, 2025 6:55:22 AM(UTC)
sinc747
Hmm. With the new release of vMix 28, sounds like the Green Room is on deck for vMix 29?
- Tom
WaltG12
#28 Posted : Monday, February 3, 2025 7:43:58 AM(UTC)
WaltG12
Nothing they've suggested--aside from learning Companion--is particularly complicated. At least, no more complicated than a proper implementation of vMix Call or Zoom into a production.
And the use of Companion can be replaced by far easier web scripting in 4K and higher, which I always recommend for a proper vMix Call implementation anyway, to make use of the additional outputs.
I'd also wonder, if vMix does opt to add this functionality (which feels to me like a big "if", but I've been surprised--and very wrong--before), what form would it take? That is to say, how much of what's being done in these scripts to build one's own greenroom will be automated by the process & how much will still have to be figured out and done by the user?
I do know of a (paid) third party service that does this, and they handle it similarly to how Zoom inputs are handled by vMix. You put in the call passwords, then they use "magic" on their backend to allow you to move people who join via their service between those calls.
Something like that could work, and is probably the best option from a user perspective, but I'm not sure how easy it'd be to implement or what impact it would have on the vMix Call operating costs.
sinc747
#29 Posted : Monday, February 3, 2025 3:38:50 PM(UTC)
sinc747
Walt,
Very interesting comments.
I take a lot of tech support calls from vMix users. At least half probably get lost going home. Many don't understand the difference between and input and an output. So setting up a green room using scripts and shortcuts would be pretty near impossible. I'm looking for something so simple that my Great Aunt Lulie could do it.
What I envision is a Green Room function to join the Audio Mixer, Replay, Lists, etc. in the bottom right quadrant of the vMix interface. It could pop out as needed. In the pop-out form it would show the video image of all vMix Callers with buttons for each caller. Join - add to green room. Exit - remove from green room. Mute - mute their audio in green room. Unmute. Preview - send caller to preview. And more of course.
Pressing the Join button for a caller would change the video image they see. This image would be preselected by the operator, It might be the operator's video or a custom multiview that might combine Program Output, Low level of Program Audio, Time Remaining, Other Callers in Green room, etc. The Caller's name (part of the vMix Call input) should be displayed as well.
In the un-Joined state, the caller might see a "waiting" screen of the Program Output, Program audio, etc. But they could not talk with anyone, they would be muted.
The Green Room pop out might be organized so that a second vMix operator could manage it much like a second operator is valuable with Replay.
Setting up the green room might include tick boxes for which inputs to include in the green room video and audio feeds.
It could be more complex, but something like this would be easy to use.
I doubt that it would affect the operating costs of vMix Call as there are no operating costs once you own a license.
Your thoughts?
- Tom
mavik
#30 Posted : Monday, June 9, 2025 4:08:17 AM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
The product to look at is TVU partyline.
And my thoughts are this:
- It should be a cloud call room (imagine you have an AGM and 20 callers to ask a question. You don't want to have the load on your production machine)
- The room should have multiple SRT listening ports so you can connect from the production securely. At least one for send (PGM) and one for receive (participant).
- The room should support audio only as well. More like an intercom style "miss-use"
- The room should offer local at the caller ISO recording including automatic upload of the media. This way people can record their question and hang up.
- Variable frame and bitrate
- and all points I have forgotten
nikosman88
#31 Posted : Tuesday, June 10, 2025 2:22:52 AM(UTC)
nikosman88
Greece
At first let`s talk about if 2 persons have the same vmix call link (that in theory they will use it in different times) and while one is on call and the 2nd decides to enter the call earlier that we agreed or 1st person speaks a little more,not to f..k up the whole call if the 2nd person tries to enter
I hope that in Vmix 29 will have "lock vmix call"
WaltG12
#32 Posted : Tuesday, June 10, 2025 3:56:06 AM(UTC)
WaltG12
I didn't see this til now, but with the tread being bumped, I'll take the opportunity to respond.
I'm not saying vMix is the easiest software in the world to learn or use.
I've been on it since at least v11 (that's the earliest support email I have), so as it's grown more sophisticated, I've grown with it.
As I've seen it change incrementally over the years, it can be hard for me to look at it in its current form as a new user would.
I've also taken to it fairly easily, so it's, again, not that easy for me to put myself in the shoes of someone who goes in not even knowing the difference between an input and and an output (to use your example).
But I do maintain that complexity has to be relative.
The level of knowledge one needs to properly build a production workflow around vMix Call that makes sense and works well is the same knowledge you need to properly build a greenroom, and is, at its core, the same level of knowledge you need to properly run an efficient vMix production.
At its core, you basically need to know what the software can and cannot do. That includes things like "what an input is" and "what falls under the available input types" and "what an audio bus is" and "what an output is" and "how to make inputs into outputs".
Those are the basics to even use the program.
While I can respect that some people may not have those down, using vMix at all really doesn't get simpler than that.
And, ultimately, the question "How do I set up a vMix Call greenroom?" is answered by a proper understanding of the above: you take whatever you want the callers to see and route it to an output the callers can see & you take the audio that you can want the callers to hear & route it to a bus the callers can hear.
It's really no more complex than using vMix itself. Some people may find it too complicated, but those are, if I can speak frankly, probably people who shouldn't be in a position where they're tasked with setting up a vMix Call greenroom (or anything else on vMix) in the first place.
Shortcuts and scripts just make it easier and faster than clicking the through the GUI manually.
I also want to point out that "operating costs", as I used the term, aren't necessarily monetary (you're talking about adding a 5th output or tying up one of the existing 4, both of which can have operational downsides), nor are they necessarily costs paid by the end user.
vMix isn't sending us the bill, but they are paying one.
What you're talking about (which sounds like a pretty good idea overall, but would probably need some tweaks) stays within the existing limits, with the exception of possibly adding a new input.
But I've seen some requests that want the greenroom to be independent of the existing call slots (and the accompanying limits) which could lead to increases of bandwidth on existing licenses.
As I said, I've been wrong before, but I wouldn't expect it. Every time this comes up, the answer has been "no".
The key is, instead, to redefine the limits.
You get a max of 8 slots.
Instead of looking at that and saying "Ok, we can build a production with up to 8 simultaneous guests", look at it as "Ok, we can build a production with up to 4 simultaneous guests".
Then you give round 1 the first 4, round 2 the second 4, round 3 the first 4, and so on.
Then you make the rounds long enough that guests aren't showing up 2 rounds early. If you can't do that, then redefine the limit again to have fewer simultaneous guests, thus giving you more queue slots.
nikosman88
#33 Posted : Tuesday, June 10, 2025 7:46:47 AM(UTC)
nikosman88
Greece
You are right from the side,you approach my "request".
Other than this,personally i cannot find any software that is more easy to learn from Vmix. If we exclude the replay feature,the simple video mixing in Vmix is the most easy to learn. I find my old panasonic hw mixer to be more difficult to handle it,compared to vmix.
I tried obs,wirecast,atem mini extreme personally and none of them is into my mind and eyes,better than vmix for the "simple user" that sinc747 says . I watched some trikaster videos and still prefer vmix way.
Your thoughts?
- Tom
My personal thoughts into this,is that No matter how simple something is, there will always be someone who finds it difficult. Just like not everyone can become a doctor, the same goes for our aunties when it comes to working in the A/V field — it's a profession like any other.
Guest (8)
2 Pages<12
