Video shrinks when making transitions/cuts
Joined: 7/23/2020(UTC) Posts: 6  Location: Texas Thanks: 1 times
Hello, The last frame of the outgoing video source shrinks before making a transition or cut to another video source. Im using 1920x1080 59.94p format on both sources. I have settings on source on both inputs. The other problem I am experiencing is that I have a video clip as input in vmix project. The video has been edited and exported as 1920x1080 but when I create the input in vmix the video appears as a 4:3 format. Why is that? I am running the latest version of vmix.  Next to last frame before cut.png (1,542kb) downloaded 0 time(s). Last frame before cut.png (1,906kb) downloaded 0 time(s). First frame after cut.png (2,565kb) downloaded 2 time(s).I am attaching three capture screens of the next to last frame before the cut transition, the last frame before the cut transition, and the first frame after the cut transition. I would appreciate any advice to these problems Thanks in advance,
Joined: 11/23/2020(UTC) Posts: 241  Location: Wichita Thanks: 11 times Was thanked: 31 time(s) in 27 post(s)
Are you using a transition with an extremely short time perhaps even a zero time to occur or using Cut to switch?
Because it seems like you may be having a transition starting but having no time to finish. Or there could be an issue in the program but I'd check how those transitions are triggered first.
Im using a simple cut but it also occurs when doing dissolves or wipes
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
Go to Settings -> Display and change the Aspect Ratio to Widescreen to solve it. "Anamorphic" is not correct for a 1080 resolution.
