ArmandTanzarian
#1 Posted : Tuesday, March 12, 2024 7:57:14 AM(UTC)
ArmandTanzarian
The last frame of the outgoing video source shrinks before making a transition or cut to another video source. Im using 1920x1080 59.94p format on both sources. I have settings on source on both inputs.
The other problem I am experiencing is that I have a video clip as input in vmix project. The video has been edited and exported as 1920x1080 but when I create the input in vmix the video appears as a 4:3 format. Why is that?
I am running the latest version of vmix.
Next to last frame before cut.png (1,542kb) downloaded 0 time(s). Last frame before cut.png (1,906kb) downloaded 0 time(s). First frame after cut.png (2,565kb) downloaded 2 time(s).
I am attaching three capture screens of the next to last frame before the cut transition, the last frame before the cut transition, and the first frame after the cut transition.
I would appreciate any advice to these problems
Thanks in advance,
Roy Sinclair
#2 Posted : Tuesday, March 12, 2024 8:08:09 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Are you using a transition with an extremely short time perhaps even a zero time to occur or using Cut to switch?
Because it seems like you may be having a transition starting but having no time to finish. Or there could be an issue in the program but I'd check how those transitions are triggered first.
ArmandTanzarian
#3 Posted : Tuesday, March 12, 2024 8:11:23 AM(UTC)
ArmandTanzarian
Im using a simple cut but it also occurs when doing dissolves or wipes
#4 Posted : Tuesday, March 12, 2024 12:08:49 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
Go to Settings -> Display and change the Aspect Ratio to Widescreen to solve it.
"Anamorphic" is not correct for a 1080 resolution.
