Joined: 2/27/2024(UTC) Posts: 8  Location: Missouri Thanks: 2 times
My Full Screen function on Vmix will not work on a consistent basis. Last Sunday it worked fine but yesterday it would not allow me to use the Dropdown feature on Fullscreen, and when it did finally open ti would not allow me to change the inputs. I have even tried it on my home computer with the same results. I have the updated version of Vmix but can't seem to get it to open or switch inputs. Any Suggestions? Need a reliable way to use full screen. michael7687@gmail.com
Joined: 1/4/2021(UTC) Posts: 5  Was thanked: 1 time(s) in 1 post(s)
I have the same issue - please let me know if you find a solution. I connect two monitors to my laptop and have used one output as a confidence monitor and the other one to assit with operating vMix
 1 user thanked Symon for this useful post.
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Under Settings->Display, under the Fullscreen section, make sure you have the correct monitor selected for the fullscreen output. You probably want to uncheck the Position checkbox as well.
 1 user thanked kross for this useful post.
It's actually an issue with vMix not recognising there is an extra monitor(s) attached to my laptop. In the dropdpown menu there is only one monitor listed - although both monitors are correctly uidentified and configured in the OS.
Joined: 1/13/2010(UTC) Posts: 5,374  Location: Gold Coast, Australia Was thanked: 4801 time(s) in 1648 post(s)
There appears to be some confusion in regards to where you are selecting the display. The Fullscreen dropdown menu is not where the display is selected, it is only for selecting a source. The Settings -> Display window is where you select the display as per the guide below: https://www.vmix.com/kno...spx/50/fullscreen-output
