Feature Requests
Audio Shortcut Feature Request
Joined: 1/11/2024(UTC) Posts: 7  Location: Dorset Was thanked: 1 time(s) in 1 post(s)
Currently a couple of my camera inputs come in with embedded audio. I split this so I can control both separately. However there is only currently an option to setup a shortcut to fade the volume on the entire input. It would be good to be able to extend this feature so that when split both channels can be faded by a shortcut independently from each other.
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Originally Posted by: TurboUK  Currently a couple of my camera inputs come in with embedded audio. I split this so I can control both separately. However there is only currently an option to setup a shortcut to fade the volume on the entire input. It would be good to be able to extend this feature so that when split both channels can be faded by a shortcut independently from each other. If you have split the channels in vMix then you should be able to use the following shortcuts: SetVolumeChannel1 SetVolumeChannel2
Yes that is correct and how I am currently setup, however they are hard audio cut, not a smooth faded transition. As we work in loud environments, sometimes we are going from a loud background audio source to a quiet spoken one. In these instances, it would be handy to have them cross fade etc.
Joined: 9/20/2023(UTC) Posts: 7  Location: Buenos Aires Thanks: 1 times
Originally Posted by: TurboUK  Currently a couple of my camera inputs come in with embedded audio. I split this so I can control both separately. However there is only currently an option to setup a shortcut to fade the volume on the entire input. It would be good to be able to extend this feature so that when split both channels can be faded by a shortcut independently from each other. +1
Feature Requests
