TurboUK
#1 Posted : Friday, February 9, 2024 11:00:12 PM(UTC)
TurboUK
Currently a couple of my camera inputs come in with embedded audio. I split this so I can control both separately. However there is only currently an option to setup a shortcut to fade the volume on the entire input. It would be good to be able to extend this feature so that when split both channels can be faded by a shortcut independently from each other.
raugert
#2 Posted : Saturday, February 10, 2024 3:21:52 AM(UTC)
raugert
Canada
If you have split the channels in vMix then you should be able to use the following shortcuts:
SetVolumeChannel1
SetVolumeChannel2
TurboUK
#3 Posted : Saturday, February 10, 2024 5:27:51 AM(UTC)
TurboUK
Yes that is correct and how I am currently setup, however they are hard audio cut, not a smooth faded transition. As we work in loud environments, sometimes we are going from a loud background audio source to a quiet spoken one. In these instances, it would be handy to have them cross fade etc.
alexis.cordoba
#4 Posted : Tuesday, April 22, 2025 10:48:30 PM(UTC)
alexis.cordoba
Argentina
+1
