barkley
#1 Posted : Sunday, June 18, 2023 7:56:39 PM(UTC)
barkley
Italy
Good morning, two quick questions on a JSON data source please.
1) If on a cell of a JSON data source I have a string like that ---> #13 Messi Lionel, is it possible somehow to take the cell as source but not take # into consideration or the JSON data source take everything's inside with no possibility to change something?
2) on a JSON API call I have a team roster and I need to do a line up of a hockey team. The graphic will be always the same but the datas inside will change match after match. Changing the url of the data source I should have the new names in the good positions.
The point is that in the source I have a column with the jersey number, one with the name, one with the role (RD, LD, RW, LW, C) and a column with the line in which they will play (1,2,3,4) and so on.
The file is sorted by jersey number and it is impossible that every team have the same jersey numbers and that (according to that) RD of line 1 is always in row 3, LD of line 1 always in row 5 and so on. Is there any possibility to tell the data source that in that position I want (instead of the number of the row) RD1 (infos that are in 2 different columns), in another LD1 and so on or should I ask the developers to change the source file?
#2 Posted : Sunday, June 18, 2023 8:36:28 PM(UTC)
Depends. if the # is part of the string with a script one can remmove that (read from title and put edited in another title field , examples in this forum) with a script
confusing (have no clue what what your codes refer to in relation to your graphics and jersey numbers that cause an issue ):
Can always let a script read the source and rearange this, if its worth the effort is another question or maybe the script can search for wwhat you want etc
YES
barkley
#3 Posted : Sunday, June 18, 2023 11:58:11 PM(UTC)
barkley
Italy
YES
Thanks Doggy basically I have a grid as you can see in the image and in every black rectangle I have a player according to his position. Positions are fixed but of course players names change match after match. I wanted to create the title with data source etc in order to have just to change the data source of next match and have the new names. The problem is that the list is sorted by jersey number and so RD1 or LD1 will never be in the same row match after match.. that's why I was asking if there is an advanced method to match that. But as far as I understood the only way is a script or change the source from the beginning.. am I right?
Test Line Up
Similar Topics
JSON data source not populating (General Discussion)
by ALCVMixAxes 6/16/2024 7:36:16 AM(UTC)
Incomplete JSON data source support (General Discussion)
by Dist 6/29/2023 9:22:25 PM(UTC)
JSON Data Source Structure (General Discussion)
by Dist 6/27/2022 9:28:28 PM(UTC)
JSON Data source from Web (General Discussion)
by bar807 12/5/2021 5:23:56 PM(UTC)
Working with Json Data Source (3rd Party Software and Development)
by jaytea 10/12/2020 9:45:39 PM(UTC)
Secure JSON Data Source (General Discussion)
by showstream 7/25/2020 12:05:41 AM(UTC)
