                Hello, I am attempting to connect a JSON data source that requires a username and password to access. Vmix is only able to give me a 401 / unauthorized error message in red. I tried including the username and password in the URL but that won't work either. Help! Thanks, Robert JSON LINK EXAMPLE https://example.edu/admin/feed.phpTHIS DOES NOT WORK EITHER https://username:password@example.edu/admin/feed.php
 Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
                Is the data source using HTTP Basic Authentication?
                Yes, the data source is using HTTP Basic Authentication
                Modern browsers don't allow basic auth authentication via the address itself, and there is AFAIK no way in vMix to authenticate basic auth for data sources.
  There are some options for you as I see.  A) If data source service allows authenticating through unique token in the url. B) Find/make a local web server that can act as proxy authenticating requests to the data source.  C) Hope vMix implements options for this. If you wish this, you should create a feature request to the forum.
