Hello ! I have a problem with the render time which is always over 35ms and I have always the warning "GPU Overloaded" even when i'm not streaming while my GPU is at 20%. I follow the tuto in the forum and LatencyMon found a problem with the Nvidia Driver. So I try to reinstall it, to install a previous version and it had no effect. Regards, Axdynx Here Capture of LatencyMon :
