Axdynx
#1 Posted : Friday, June 9, 2023 9:19:35 PM(UTC)
Axdynx
Hello !
I have a problem with the render time which is always over 35ms and I have always the warning "GPU Overloaded" even when i'm not streaming while my GPU is at 20%.
I follow the tuto in the forum and LatencyMon found a problem with the Nvidia Driver. So I try to reinstall it, to install a previous version and it had no effect.
Axdynx
Here Capture of LatencyMon :
https://cdn.discordapp.com/attachments/862038107679096844/1116687168253993041/latencymon_main.png
https://cdn.discordapp.com/attachments/862038107679096844/1116687168593735820/latencymon_stats.png
https://cdn.discordapp.com/attachments/862038107679096844/1116687168933462026/latencymon_processes.png
https://cdn.discordapp.com/attachments/862038107679096844/1116687169277407232/latencymon_drivers.png
https://cdn.discordapp.com/attachments/862038107679096844/1116687169763934248/latencymon_cpus.png
#2 Posted : Saturday, June 10, 2023 8:32:53 PM(UTC)
@ Axdynx
High Render times will typically be for the reasons listed in this Knowledge Base page (which appears to fall in line with what LatencyMon found):
https://www.vmix.com/kno...nosing-high-render-times
Similar Topics
Laggy High Render Times. Upgrade help? (Hardware Compatibility)
by Lastmarine 5/13/2025 7:05:19 PM(UTC)
High render times (NDI)
by TimCac 12/15/2020 3:23:52 AM(UTC)
High Render Times with 2 Outputs (General Discussion)
by Slaver 11/25/2020 10:16:21 PM(UTC)
New Dell G7s i7-10750H RTX 2070-Max Q high render times (General Discussion)
by Vince Beck 8/13/2020 3:43:33 AM(UTC)
High render times after vmix 23.0.0.49 update (General Discussion)
by Dune 4/11/2020 12:11:57 PM(UTC)
High Render Times / Dropping Frames (General Discussion)
by kgoodyer 5/5/2019 9:56:39 AM(UTC)
High render times + FPS drops. CPU & GPU usage are low. Help? (General Discussion)
by RandomStreamer 5/19/2017 9:08:19 AM(UTC)
