Hi Community,
I have a MSI MSI Raider GE76 12UGS with integrated gpu and a dedicated RTX3070Ti and Vmix wont start with the error
graphics hardware not supported DirectX 9 compatible Hardware required D3DStartup.D3D_NEW_EX D3DERR_NOTAVAILABLE: nOT aVAILABLE (-2005530518)
I have assigned the 3070ti in the nvidia control panel for Vmix I have assigned on advanced graphics config of the W10 enterprise 1809 to the executables Vmix.exe and Vmix64.exe to work with the dedicated GPU (high performance) I don't know what else to do because I have tried different driver versions I can see on the DXdiag that everything is ok but Screen 1, the laptop screen says that is working with the Intel Iris XE and if I connect a screen on the HDMI output says that the screen2 is working with the RTX3070ti, this is the way I have bypass this particular error on another laptop that I have MSI Raider GE66 12UGS but I dont know why Vmix can not start. It looks that the software make a check if a compatible card is on the system but in this particular case it is but refuses to work with. What else I can do? I'm really frustrated it is a pretty good system and I cant work with it and I need it badly in the following days and I didnt find anything to try looking on the web and forms. Thanks for the help and best regards, hope somebody can give me some directions to follow. Greetings from Spain.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
