Headphone monitoring while outputting to HDMI
Joined: 5/28/2023(UTC) Posts: 5  Location: South Carolina
New streaming setup from our sports league. We output to a Videon encoder (displayport to hdmi from a RTX3060) which then streams out to our provider via internet. We also output NDI at the same time within our private network for low latency displays at the same time - NDI output never has an audio problem.
When Windows 11 has Videon set as default output I lose headphone monitoring, when headphones set as default I lose audio on Videon output.
Activated Stereo Mix in Windows and added either device as a second output device and the other as the default device. Only the default device has audio. same as before.
Any suggestions, it's a real pain not to be able to monitor during streaming. Oh, latest Vmix4K version.
Joined: 7/1/2020(UTC) Posts: 105  Location: Earth Was thanked: 23 time(s) in 20 post(s)
vmix settings, audio output
set master output to be your hdmi/gpu device set headphone out to be your headphone/soundcard device
Sounds reasonable. Will test it tomorrow.
Thanks for the quick response.
Worked perfectly. Thank you
