DesktopJ
#1 Posted : Sunday, May 28, 2023 2:39:45 AM(UTC)
DesktopJ
New streaming setup from our sports league. We output to a Videon encoder (displayport to hdmi from a RTX3060) which then streams out to our provider via internet. We also output NDI at the same time within our private network for low latency displays at the same time - NDI output never has an audio problem.
When Windows 11 has Videon set as default output I lose headphone monitoring, when headphones set as default I lose audio on Videon output.
Activated Stereo Mix in Windows and added either device as a second output device and the other as the default device. Only the default device has audio. same as before.
Any suggestions, it's a real pain not to be able to monitor during streaming. Oh, latest Vmix4K version.
AudioGreg
#2 Posted : Sunday, May 28, 2023 4:07:27 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
vmix settings, audio output
set master output to be your hdmi/gpu device
set headphone out to be your headphone/soundcard device
DesktopJ
#3 Posted : Sunday, May 28, 2023 4:43:07 AM(UTC)
DesktopJ
Sounds reasonable. Will test it tomorrow.
Thanks for the quick response.
DesktopJ
#4 Posted : Tuesday, May 30, 2023 6:31:34 AM(UTC)
DesktopJ
Worked perfectly. Thank you
