Help - Setting up a trigger to work with Virual set inputs
Greetings,
I am a new user working with VMix in my trial period. I have been using the application to create content for my social media channels.
I am trying to set up a trigger that will automatically change the input of a Virtual Set at a specific point during the the clip
For example, I am creating a news show and on Screen 3 of the Virtual set, I have an input of a clip from APnews. After 10 seconds of the clip, I want the input to change to another clip of a different story on Reuters, and so forth.
Any help would be appreciated to know if this is possible.
Joined: 12/27/2012(UTC) Posts: 5,497  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Scripting will be your best bet: play video , have a counter within your script , when counter is at end change layer of virtual set with next clip start counter again for next or use a list as input for the layer of ( edited ) clips is also an option
Greetings! I was able to use the list functionality with a little editing to the videos as you mentioned. Do you know if it is possible to add pauses to the list without pausing the stream
Originally Posted by: Reach4thelight  Greetings! I was able to use the list functionality with a little editing to the videos as you mentioned. Do you know if it is possible to add pauses to the list without pausing the stream What have you tried ? What about "PlayPause" the list input ? Might be worth it to Go through all the available shortcut function and check what they do and play with them to understand them Oh and there is a shortcut reference list in the helpfile too, IMO the function names are pretty obvious
Thanks, Doggy, you have been a great help, and I am working through them now. The shortcuts and triggers are especially helpful as I am producing and recording everything myself
