Reach4thelight
#1 Posted : Tuesday, March 28, 2023 6:15:52 AM(UTC)
Reach4thelight
Greetings,
I am a new user working with VMix in my trial period. I have been using the application to create content for my social media channels.
I am trying to set up a trigger that will automatically change the input of a Virtual Set at a specific point during the the clip
For example, I am creating a news show and on Screen 3 of the Virtual set, I have an input of a clip from APnews. After 10 seconds of the clip, I want the input to change to another clip of a different story on Reuters, and so forth.
Any help would be appreciated to know if this is possible.
#2 Posted : Tuesday, March 28, 2023 7:34:37 AM(UTC)
Originally Posted by: Reach4thelight Go to Quoted Post
Greetings,
Scripting will be your best bet:
play video , have a counter within your script , when counter is at end change layer of virtual set with next clip start counter again for next
or use a list as input for the layer of ( edited ) clips is also an option
Reach4thelight on 3/29/2023(UTC)
Reach4thelight
#3 Posted : Wednesday, March 29, 2023 4:22:22 AM(UTC)
Reach4thelight
Greetings! I was able to use the list functionality with a little editing to the videos as you mentioned. Do you know if it is possible to add pauses to the list without pausing the stream
#4 Posted : Wednesday, March 29, 2023 4:41:39 AM(UTC)
What have you tried ?
What about "PlayPause" the list input ?
Might be worth it to Go through all the available shortcut function and check what they do and play with them to understand them
Oh and there is a shortcut reference list in the helpfile too, IMO the function names are pretty obvious
Reach4thelight
#5 Posted : Wednesday, March 29, 2023 4:45:26 AM(UTC)
Reach4thelight
Thanks, Doggy, you have been a great help, and I am working through them now. The shortcuts and triggers are especially helpful as I am producing and recording everything myself
