OBS recently introduced a new feature that enables to exclude specific tracks (e.g. music) from the VOD that Twitch will automatically save. As DMCA takedowns have become a thing, it would be useful if vMix would support this feature.
 1 user thanked pheno for this useful post.
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
+1 or a tutorial at least
Any updates/solutions here? This is the ONLY thing preventing me from switching away from OBS. Any information would be greatly appreciated!
Same here. Would LOVE to get a separate VOD track for twitch!
I did find a work around - by using vMix's External output -> add input as source in OBS, then use whatever you need to bring in audio. Not sure how to get the vMix audio channel buses into OBS though...
Originally Posted by: jammerxd  I did find a work around - by using vMix's External output -> add input as source in OBS, then use whatever you need to bring in audio. Not sure how to get the vMix audio channel buses into OBS though... You could achieve this by using Dante Via or a Virtual Audio Cable when you go to your audio outputs in your settings and changing the Bus output from "enabled" to Via or a VAC. You can also enable NDI outputs for audio buses in the external outputs/NDI menu.
Dante Via - costs money and usually requires an entirely separate PC just because it seems to have timing/sync issues otherwise, also requires it's own subnet/vlan tag so that it doesn't get lost/spam the network (further more their uninstaller messed up all my other sound devices completely forcing me to reinstall windows)
Virtual Audio Cable - these have never worked for me without crackling, stuttering, or drops in signal, never been able to solve it without adding +50-100ms of latency and seems like the folks that make it have no intention of resolving this
NDI - while a good solution, even on a hardwired home network with gigabit ethernet, there is still a good 30-50ms delay on any input/output, thus causing de-sync between audio and video - and that's without games or livestreaming
There's just no good way other than direct capture to keep things in sync - and it's not like I have a potato for hardware either
Circling back on this - it seems vmix and OBS cannot co-exist together on the laptop I have. Not sure about desktop. But I get lots of dropped frames with OBS and vmix running simultaneously. For reference the laptop I'm running is an MSI GS75 Stealth 9SG with the following:
32GB RAM Intel HD 630 Graphics RTX 2080 With Max-Q Design Intel i7-9750H CPU - 2.6GHz, turbo 4.5GHz
So it's not like it's a bad spec or anything.
But the gist of it is yeah I need the twitch VOD track for music.
It's really the only thing stopping me from getting maximum smoothness on my streams.
Rank:: Member
Bump and Plus 1.
I do a live sports talk show everyday, would love to have music in the background LIVE but not in the vod. I know I could record the show sans audio but that's creating a ton of extra steps, not to mention it messes with the "views" count.
