pheno
#1 Posted : Sunday, February 7, 2021 1:44:22 AM(UTC)
pheno
OBS recently introduced a new feature that enables to exclude specific tracks (e.g. music) from the VOD that Twitch will automatically save. As DMCA takedowns have become a thing, it would be useful if vMix would support this feature.
thanks 1 user thanked pheno for this useful post.
jammerxd on 3/14/2023(UTC)
Torg
#2 Posted : Sunday, October 3, 2021 4:24:45 AM(UTC)
Torg
+1 or a tutorial at least
yevotv
#3 Posted : Thursday, February 16, 2023 2:19:51 PM(UTC)
yevotv
Any updates/solutions here? This is the ONLY thing preventing me from switching away from OBS. Any information would be greatly appreciated!
jammerxd
#4 Posted : Monday, March 13, 2023 5:22:20 AM(UTC)
jammerxd
Same here. Would LOVE to get a separate VOD track for twitch!
jammerxd
#5 Posted : Tuesday, March 14, 2023 10:18:45 AM(UTC)
jammerxd
I did find a work around - by using vMix's External output -> add input as source in OBS, then use whatever you need to bring in audio. Not sure how to get the vMix audio channel buses into OBS though...
haloflyer
#6 Posted : Tuesday, March 21, 2023 9:57:24 AM(UTC)
haloflyer
You could achieve this by using Dante Via or a Virtual Audio Cable when you go to your audio outputs in your settings and changing the Bus output from "enabled" to Via or a VAC. You can also enable NDI outputs for audio buses in the external outputs/NDI menu.
jammerxd
#7 Posted : Friday, March 24, 2023 3:12:36 AM(UTC)
jammerxd
Dante Via - costs money and usually requires an entirely separate PC just because it seems to have timing/sync issues otherwise, also requires it's own subnet/vlan tag so that it doesn't get lost/spam the network (further more their uninstaller messed up all my other sound devices completely forcing me to reinstall windows)
Virtual Audio Cable - these have never worked for me without crackling, stuttering, or drops in signal, never been able to solve it without adding +50-100ms of latency and seems like the folks that make it have no intention of resolving this
NDI - while a good solution, even on a hardwired home network with gigabit ethernet, there is still a good 30-50ms delay on any input/output, thus causing de-sync between audio and video - and that's without games or livestreaming
There's just no good way other than direct capture to keep things in sync - and it's not like I have a potato for hardware either
jammerxd
#8 Posted : Monday, April 3, 2023 4:11:09 AM(UTC)
jammerxd
Circling back on this - it seems vmix and OBS cannot co-exist together on the laptop I have. Not sure about desktop. But I get lots of dropped frames with OBS and vmix running simultaneously. For reference the laptop I'm running is an MSI GS75 Stealth 9SG with the following:
32GB RAM
Intel HD 630 Graphics
RTX 2080 With Max-Q Design
Intel i7-9750H CPU - 2.6GHz, turbo 4.5GHz
So it's not like it's a bad spec or anything.
But the gist of it is yeah I need the twitch VOD track for music.
It's really the only thing stopping me from getting maximum smoothness on my streams.
barryondeck
#9 Posted : Thursday, May 11, 2023 11:25:45 PM(UTC)
barryondeck
Bump and Plus 1.
I do a live sports talk show everyday, would love to have music in the background LIVE but not in the vod. I know I could record the show sans audio but that's creating a ton of extra steps, not to mention it messes with the "views" count.
Guest (4)
