cutter07
#1 Posted : Friday, July 4, 2014 2:36:51 PM(UTC)
cutter07
I'm looking for a realtime blur effect, maybe it's already possible.?
richardgatarski
#2 Posted : Tuesday, July 8, 2014 8:16:07 AM(UTC)
richardgatarski
Not the same cigar, but one alternative is to create a png file with a semi transparent color (eg white or black) for the areas you want blurred. Then Overlay that png (or add in in a Multview).
rrpro
#3 Posted : Tuesday, July 8, 2014 11:11:24 AM(UTC)
rrpro
The future I'm seeing is to create a tab of Video FX on the channel with multiple effects and probably plugins IF it is possible. It would unlock possibilities.
But I don't give this a lot of prioritie....
rwardley
#4 Posted : Saturday, July 19, 2014 11:41:12 AM(UTC)
rwardley
I too was looking for a real time blur feature, although, as already suggested, a semi-transparent png will probably do the trick for now.
I believe a video FX tab on a channel would be a really useful feature.
