Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
I'm looking for a realtime blur effect, maybe it's already possible.?
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Not the same cigar, but one alternative is to create a png file with a semi transparent color (eg white or black) for the areas you want blurred. Then Overlay that png (or add in in a Multview).
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
The future I'm seeing is to create a tab of Video FX on the channel with multiple effects and probably plugins IF it is possible. It would unlock possibilities.
But I don't give this a lot of prioritie....
I too was looking for a real time blur feature, although, as already suggested, a semi-transparent png will probably do the trick for now. I believe a video FX tab on a channel would be a really useful feature.
