#1 Posted : Friday, July 4, 2014 2:17:37 AM(UTC)
Anyone knows sources to buy the Magewell XI100DUSB-HDMI especially mainland Europe ?
So far I found one US option and one UK(but no prices) one.
Seems a bit odd if its that good and 'popular'
r@wisla
#2 Posted : Saturday, July 5, 2014 7:01:15 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
http://zenvideo.co.uk/magewell.htm
http://planetdv.net/Addi...agewell/External-Capture
http://meet-com.de/shop/.../category&path=64_65
#3 Posted : Saturday, July 5, 2014 7:22:36 AM(UTC)
Thank you
Crazy price difference depending on the neighbouring country !
r@wisla
#4 Posted : Saturday, July 5, 2014 10:23:10 AM(UTC)
r@wisla
doggy wrote:
Thank you
Looks like the lowest price is in Germany, so You should be satisfied.
thanks 1 user thanked r@wisla for this useful post.
doggy on 7/5/2014(UTC)
fey13
#5 Posted : Thursday, January 15, 2015 2:46:35 PM(UTC)
fey13
Hi, can someone help me ? I just want to know, if i use two or more Magewell XI100DUSB-HDMI for the same numbers of cameras (multicam), will be there a delay between them. And if so, would it be the same all the time i connect it, or it will be different each time ? Thank you.
Speegs
#6 Posted : Thursday, January 22, 2015 5:06:33 AM(UTC)
Speegs
I'm not sure if I entirely understand what you mean by muticam. 1st magewell connected to 1st camera. 2nd magewell connected to 2nd camera. Same computer I'm assuming. So best I answer this way.
I have used 2 x Magewell XI100DUSB-HDMI on a Macbook Pro (Running Windows via Bootcamp) and via a custom built PC Rig with 2+ cameras and they seem to be in sync. If there is a difference in latency it would have been less than 2 frames per second as I couldn't detect it.
Make sure you have full speed USB 3 ports and on separate controllers. Sometimes USB 3 two ports might share a controller, depends on the computer.
thanks 1 user thanked Speegs for this useful post.
fey13 on 1/24/2015(UTC)
fey13
#7 Posted : Saturday, January 24, 2015 7:06:00 AM(UTC)
fey13
Yes, you understood me correctly. Thank U.
Speegs
#8 Posted : Saturday, January 24, 2015 9:12:47 AM(UTC)
Speegs
No worries, you don't want to waste hours and sometimes days trying to get stuff going, that never had a chance to get working properly I've been there too many times.
Tom
#9 Posted : Tuesday, February 24, 2015 4:03:41 PM(UTC)
Tom
doggy wrote:
Thank you
Hey doggy,
Where have you bought the item, and are you happy with it? I'm considering it too.
Guest (5)
Similar Topics
Magewell XI100DUSB-HDMI Setup (Hardware Compatibility)
by bozzdroid 2/7/2015 12:38:43 PM(UTC)
Magewell XI100DUSB-HDMI Frames Dropping in Statistics (Hardware Compatibility)
by pjtgrizzly 12/19/2014 7:20:53 PM(UTC)
