Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Anyone knows sources to buy the Magewell XI100DUSB-HDMI especially mainland Europe ?
So far I found one US option and one UK(but no prices) one. Seems a bit odd if its that good and 'popular'
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Thank you
Crazy price difference depending on the neighbouring country !
doggy wrote:Thank you
Crazy price difference depending on the neighbouring country ! Looks like the lowest price is in Germany, so You should be satisfied.
 1 user thanked r@wisla for this useful post.
Hi, can someone help me ? I just want to know, if i use two or more Magewell XI100DUSB-HDMI for the same numbers of cameras (multicam), will be there a delay between them. And if so, would it be the same all the time i connect it, or it will be different each time ? Thank you.
fey13 wrote:Hi, can someone help me ? I just want to know, if i use two or more Magewell XI100DUSB-HDMI for the same numbers of cameras (multicam), will be there a delay between them. And if so, would it be the same all the time i connect it, or it will be different each time ? Thank you. I'm not sure if I entirely understand what you mean by muticam. 1st magewell connected to 1st camera. 2nd magewell connected to 2nd camera. Same computer I'm assuming. So best I answer this way. I have used 2 x Magewell XI100DUSB-HDMI on a Macbook Pro (Running Windows via Bootcamp) and via a custom built PC Rig with 2+ cameras and they seem to be in sync. If there is a difference in latency it would have been less than 2 frames per second as I couldn't detect it. Make sure you have full speed USB 3 ports and on separate controllers. Sometimes USB 3 two ports might share a controller, depends on the computer.
 1 user thanked Speegs for this useful post.
Speegs wrote:fey13 wrote:Hi, can someone help me ? I just want to know, if i use two or more Magewell XI100DUSB-HDMI for the same numbers of cameras (multicam), will be there a delay between them. And if so, would it be the same all the time i connect it, or it will be different each time ? Thank you. I'm not sure if I entirely understand what you mean by muticam. 1st magewell connected to 1st camera. 2nd magewell connected to 2nd camera. Same computer I'm assuming. So best I answer this way. I have used 2 x Magewell XI100DUSB-HDMI on a Macbook Pro (Running Windows via Bootcamp) and via a custom built PC Rig with 2+ cameras and they seem to be in sync. If there is a difference in latency it would have been less than 2 frames per second as I couldn't detect it. Make sure you have full speed USB 3 ports and on separate controllers. Sometimes USB 3 two ports might share a controller, depends on the computer. Yes, you understood me correctly. Thank U.
fey13 wrote: Yes, you understood me correctly. Thank U.
No worries, you don't want to waste hours and sometimes days trying to get stuff going, that never had a chance to get working properly I've been there too many times.
Crazy price difference depending on the neighbouring country ! Hey doggy, Where have you bought the item, and are you happy with it? I'm considering it too.
