Audio issue with XAVC wrapped as MXF
Hi Guys, I recorded some files with Sony PXW-Z190 camcorders in XAVC format with 4 channels of audio (2 external microphones on CH1 and Ch2 and internal microphone L-R on CH3 and Ch4). When I add the files as inputs in vMix only the first audio channel (Ch1) of the recording is associated on the audio side with the respective input; this channel is sent on both left and right channels of the respective input.
To be noted that I am using the latest version of vMix software.
And here is the media info of the file:
Format : MXF at 51.3 Mb/s Length : 7.84 GiB for 21 min 54 s 520 ms
Video #0 : AVC at 46.6 Mb/s Aspect : 1920 x 1080 (1.778) at 50.000 fps
Audio #0 : PCM at 1 152 kb/s Infos : 1 channel, 48.0 kHz
Audio #1 : PCM at 1 152 kb/s Infos : 1 channel, 48.0 kHz
Audio #2 : PCM at 1 152 kb/s Infos : 1 channel, 48.0 kHz
Audio #3 : PCM at 1 152 kb/s Infos : 1 channel, 48.0 kHz
So... here we are , two years later, and this is problem with audio channels in mxf is still not resolved. Any hope it ever will be?
good suggestion...I've been waiting for it for a long time too
Hi, I made a small app that allows you to remap audio channels in an MXF into 2 and 4 channels. The output files can be used in vMix with the correct channel separation MXF 2 and 4 channel remapper
