ClaudiuCiprian
#1 Posted : Wednesday, March 18, 2020 3:36:14 AM(UTC)
ClaudiuCiprian
Hi Guys, I recorded some files with Sony PXW-Z190 camcorders in XAVC format with 4 channels of audio (2 external microphones on CH1 and Ch2 and internal microphone L-R on CH3 and Ch4). When I add the files as inputs in vMix only the first audio channel (Ch1) of the recording is associated on the audio side with the respective input; this channel is sent on both left and right channels of the respective input.
To be noted that I am using the latest version of vMix software.
And here is the media info of the file:
Format : MXF at 51.3 Mb/s
Length : 7.84 GiB for 21 min 54 s 520 ms
Video #0 : AVC at 46.6 Mb/s
Aspect : 1920 x 1080 (1.778) at 50.000 fps
Audio #0 : PCM at 1 152 kb/s
Infos : 1 channel, 48.0 kHz
Audio #1 : PCM at 1 152 kb/s
Audio #2 : PCM at 1 152 kb/s
Audio #3 : PCM at 1 152 kb/s
RuneK
#2 Posted : Thursday, May 5, 2022 6:25:37 PM(UTC)
RuneK
Norway
So... here we are , two years later, and this is problem with audio channels in mxf is still not resolved. Any hope it ever will be?
RuneK
#3 Posted : Thursday, May 5, 2022 8:25:36 PM(UTC)
RuneK
Norway
Jurgen
#4 Posted : Thursday, January 12, 2023 5:33:52 AM(UTC)
Jurgen
good suggestion...I've been waiting for it for a long time too
Jurgen
#5 Posted : Thursday, January 12, 2023 7:51:01 AM(UTC)
Jurgen
I made a small app that allows you to remap audio channels in an MXF into 2 and 4 channels.
The output files can be used in vMix with the correct channel separation
MXF 2 and 4 channel remapper
