mat946
#1 Posted : Saturday, November 26, 2022 12:56:18 AM(UTC)
mat946
Poland
Hi there, I've just bought new PC for streaming and I'm quite new with vmix, so I decided to use recommended hardware.
My elgato PCI CamLink pro is loosing frames. In elgato capture software picture is very smooth, but when I capture it through vmix I get choppy video/stream.
My PC I9 12900K 64GB Ram RTX3080 m2 drives, Win 11
I have another capture card from blackmagic, decklink 2 SDI and video signal from this card is perfect.
dmwkr
#2 Posted : Saturday, November 26, 2022 2:32:01 AM(UTC)
dmwkr
Same question and comment as here: https://forums.vmix.com/...-Cam-Link-Pro#post104406
nikosman88
#3 Posted : Saturday, November 26, 2022 6:02:39 AM(UTC)
nikosman88
Greece
1.When you import your camlink in vmix in format section change the YUV to MJPEG and see if you`re ok
2.See this https://www.vmix.com/kno...apture-devices-with-vmix
hellokitty
#4 Posted : Thursday, December 22, 2022 6:14:01 AM(UTC)
hellokitty
make shure your using a non shared usb port, and also set it for isochronous. you ctrl clik the settings in the camera hub app. that should help.
