Hardware Compatibility
Elgato CamLink Pro loosing frames
Joined: 10/31/2022(UTC) Posts: 4  Location: Warsaw Thanks: 1 times
Hi there, I've just bought new PC for streaming and I'm quite new with vmix, so I decided to use recommended hardware. My elgato PCI CamLink pro is loosing frames. In elgato capture software picture is very smooth, but when I capture it through vmix I get choppy video/stream.
My PC I9 12900K 64GB Ram RTX3080 m2 drives, Win 11 I have another capture card from blackmagic, decklink 2 SDI and video signal from this card is perfect.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: mat946  Hi there, I've just bought new PC for streaming and I'm quite new with vmix, so I decided to use recommended hardware. My elgato PCI CamLink pro is loosing frames. In elgato capture software picture is very smooth, but when I capture it through vmix I get choppy video/stream.
1.When you import your camlink in vmix in format section change the YUV to MJPEG and see if you`re ok 2.See this https://www.vmix.com/kno...apture-devices-with-vmix
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
make shure your using a non shared usb port, and also set it for isochronous. you ctrl clik the settings in the camera hub app. that should help.
