28 Pages«<1415161718>»
Salvatore
#301 Posted : Wednesday, November 16, 2022 2:35:25 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
i'm trying to search for a Input which contains a text part.
Example:
Input Name: "Startscreen_Main"
I'm looking only for the text "Startscreen"
something like:
dim Startscreen as string = (x.SelectSingleNode("//input[@title.contains='Startscreen']/@number").Value)
#302 Posted : Wednesday, November 16, 2022 4:03:51 AM(UTC)
Example:
something like:
You probably would have found it quicker using Google search (xml xpath contains) instead of guessing ;-)
for example: https://stackoverflow.com/questions/103325/what-is-the-correct-xpath-for-choosing-attributes-that-contain-foo
Code:
dim Startscreen as string= (x.SelectSingleNode("//input[contains(@title,'Startscreen')]/@number").Value)
Salvatore
#303 Posted : Wednesday, November 16, 2022 10:10:08 AM(UTC)
Salvatore
Italy
you're probably right, but this way everyone benefits ;-)
Thanks doggy
Joeboe
#304 Posted : Thursday, November 17, 2022 8:45:52 AM(UTC)
Joeboe
I am trying to write a script to fade with a duration of 7 secs., but I keep getting 500Ms....(half Sec.)
Function=Fade&Value=0,7000
where I am I going wrong, or what am I missing?
Thanks in advance
Joeboe
#305 Posted : Thursday, November 17, 2022 9:40:42 AM(UTC)
Joeboe
I ended up using a trigger, and it works.....I can now fade to black with a duration of 7 secs....and I can vary the time....was simple, and quick....
David BCS
#306 Posted : Thursday, November 17, 2022 7:49:09 PM(UTC)
David BCS
Hello!
Is it possible to replace "http://127.0.0.1:8088/api" to custom IP, which belongs to another computer in local network in this part?
dim xml = API.XML()
x.loadxml(xml)
#307 Posted : Thursday, November 17, 2022 8:31:22 PM(UTC)
Originally Posted by: David BCS Go to Quoted Post
Hello!
dim xml = API.XML()
x.loadxml(xml)
Sure you can load it from another computer (with the correct IP )
lots of examples
EDIT: the location of the vMix API XML is http://xxx.xxx.xxx.xxx:8088/API (one can check it in your browser)
#308 Posted : Thursday, November 17, 2022 8:37:16 PM(UTC)
Confused: you asked first about a Fade duration (as in transition : Function=Fade) to your it's working to be a FTB (FadeToBlack) ?
David BCS
#309 Posted : Thursday, November 17, 2022 8:58:20 PM(UTC)
David BCS
I meant how to parse API.XML of another computer
my solution (I'm not fluent in programming):
Code:
dim wc as WebClient = new WebClient()
wc.DownloadFile("http://192.168.88.11:8088/api", "C:\Users\admin\Desktop\getxml.xml")
dim doc as XmlDocument = new XmlDocument()
doc.Load("C:\Users\admin\Desktop\getxml.xml")
dim x as XmlElement = doc.DocumentElement
instead of
Code:
dim xml = API.XML()
x.loadxml(xml)
Joeboe
#310 Posted : Thursday, November 17, 2022 9:09:59 PM(UTC)
Joeboe
Let me explain....I was trying to write a script to fade to black, with all audio sourses fading at the same time, then audio off at the end of the fade, and all players paused.....I have other scripts that do cross fades and other functions, and the reversals...... but I needed this for a production, as I do not want to use the FTB in vmix... I want to have many functions happening at the same time, and then I want to have a reversal of the same, to fade up from a black screen, with other functions fading up at the same time.....I ended up using triggers, but even though that works, and was not difficult to do, I would prefer a script, using the type of code I posted.....any help would be very helpful.....
Here is a script I use to do a cross fade...I have since added more lines of script for other functions.and also did a reversal of this script, and it works ok for what I am doing....I want to add a fade to black to this, where Black is a colour input (e.g. input 7)
Function=SetVolumeFade&Input=Audio Digital Audio Interface&Value=85,6000
Function=SetVolumeFade&Input=HYMNS&Value=0,6000
Function=SetVolumeFade&Input=PLAYER 1&Value=0,6000
Function=SetVolumeFade&Input=PLAYER 2&Value=0,6000
Function=SetVolumeFade&Input=PLAYER 3&Value=0,6000
I also use the FTB for streaming, where I would slowly fade to black, sleep for 10 secs., then stop stream, stop recording, all at the same time....like I said, the triggers work perfect, but I want to use a script, so I can transfer to other systems, as I can not find a way to export the triggers, and do not want to have to write everything all over each time I use a different PC.....
#311 Posted : Friday, November 18, 2022 1:53:32 AM(UTC)
Copy/paste the script to a textfile and then to other computer
Also there is a Export and Import button in the scripting editor !!!!!!
Joeboe
#312 Posted : Friday, November 18, 2022 2:23:51 AM(UTC)
Joeboe
I do not know how to export the triggers...if that is possible
#313 Posted : Friday, November 18, 2022 3:05:19 AM(UTC)
They are included in the presets (or bundle designed for transfering to other computer)
Extracting them from and Reinserting them in a preset out of vMix is possible but beyond the scope of this 'scripting for dummies' post
Joeboe
#314 Posted : Friday, November 18, 2022 3:10:59 AM(UTC)
Joeboe
ok, thanks.....wish I knew how.....Guess I will have to try using the preset on another system, and see if the triggers get copied
#315 Posted : Friday, November 18, 2022 3:38:00 AM(UTC)
No you don't as its kind of hacking preset files . Fun until things go wrong (and blame vMix)
Joeboe
#316 Posted : Friday, November 18, 2022 6:33:44 AM(UTC)
Joeboe
Yes....even though I was able to do a workaround using triggers, I would still like to have a script to be able to do the FTB in 7 secs....which would be much easier, as I could have the script on a pendrive, and saved on my HD that I can transfer much faster..
What I did, was to have a colour input, in my case Black, and on transition in, I have it timed for 7 secs, with all my audio sourses set to fade for 7 secs....and a shortcut to select Black as a preview so that it will be in preview for the fade transition, and it works great.....but I still need a script, and I seem to be missing something in the code.....all other things are working, but the fade to Black just does not work.
nikosman88
#317 Posted : Friday, November 18, 2022 8:02:40 AM(UTC)
nikosman88
Rank:: Advanced Member
Greece
Hello. Try the command like this
Function=Fade&Input=nameyourblackinput&Duration=7000&Mix=0
Joeboe
#318 Posted : Friday, November 18, 2022 8:43:16 AM(UTC)
Joeboe
Thanks Nickosman88, it works perfect....Now I can comlete my full script
Thanks a lot
Joeboe
#319 Posted : Tuesday, November 22, 2022 7:35:33 AM(UTC)
Joeboe
Hi all, Was trying to use an old scoreboard from vMix, but I find it will not function anymore....It seems that Dynamic Scripting is no longer working...I am on vMix 25...I had created this script in the regular titler, but now I have problems getting it to work, and even in GT Tltler, I can not get the scores to advance ... Need some help here, as I am preparing for a Tennis tournament in a few days..
mirrormatt86
#320 Posted : Friday, December 16, 2022 6:21:40 PM(UTC)
mirrormatt86
'Is a input Running or on Pause retrieved from the API xml
dim xml = API.XML()
x.loadxml(xml)
dim StateOf = (x.SelectSingleNode("//input[@type='Replay']/@state").Value)
'or
dim StateOf = (x.SelectSingleNode("//input[@number='10']/@state").Value)
Console.WriteLine(StateOf)
so this results in an error. Great scripting "for dummies"
