Iam having shuttering freezing problem while recording pc game in recorded file
Joined: 10/23/2022(UTC) Posts: 2  Location: marryland Thanks: 2 times
hello, iam recording a game using ndi/local desktop capture and in desktop capture i select game then i use setting windows graphics capture,my recording settings are MP4 1980x1080 NTSC 59.94p , bit rate 4 ,profile h264 baseline, use hardware encoder enabled ,when i play game while recording everything is smooth but when i playback the recorded file it freezez shutters alot, i have also checked everyother format also like avi ,wmc ,i have checked VLC ,windows media player all result is same the recorded file is not smooth  aa.jpg (646kb) downloaded 6 time(s).,my pc profile is intel core i7 4970 16gb ddr3 ram rx570 4gb graphics card windows 10 ,can please someone help me to guide a smooth pc gaming recording,sorry for my english ,thankyou
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi looks like ur cpu/gpu or its dedicated RAM is not enough for doing this ! so please send ur computer specs and i will tell u the sw/hw solution.
 1 user thanked Winops for this useful post.
Here's something to try...
Increase your Bit Rate to 25 and the Profile to H.264Main.
Also, you might mention which drive you are recording to. If it's a HDD, it should be 7200RPM or better. Also better that you not record to your C: drive.
Best wishes.
- Tom
 1 user thanked sinc747 for this useful post.
iam recording on ssd . my pc specs are core i7 4790 ddr3 16gb ram graphics card AMD RX570 4GB
