fast666
#1 Posted : Sunday, October 23, 2022 4:05:46 PM(UTC)
fast666
hello,
iam recording a game using ndi/local desktop capture and in desktop capture i select game then i use setting windows graphics capture,my recording settings are MP4 1980x1080 NTSC 59.94p , bit rate 4 ,profile h264 baseline, use hardware encoder enabled ,when i play game while recording everything is smooth but when i playback the recorded file it freezez shutters alot, i have also checked everyother format also like avi ,wmc ,i have checked VLC ,windows media player all result is same the recorded file is not smooth aa.jpg (646kb) downloaded 6 time(s).,my pc profile is intel core i7 4970 16gb ddr3 ram rx570 4gb graphics card windows 10 ,can please someone help me to guide a smooth pc gaming recording,sorry for my english ,thankyou
User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#2 Posted : Sunday, October 23, 2022 7:21:08 PM(UTC)
Winops
Argentina
hi
looks like ur cpu/gpu or its dedicated RAM is not enough for doing this !
so please send ur computer specs
and i will tell u the sw/hw solution.
thanks 1 user thanked Winops for this useful post.
fast666 on 10/24/2022(UTC)
sinc747
#3 Posted : Monday, October 24, 2022 12:40:15 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Here's something to try...
Increase your Bit Rate to 25 and the Profile to H.264Main.
Also, you might mention which drive you are recording to. If it's a HDD, it should be 7200RPM or better. Also better that you not record to your C: drive.
Best wishes.
- Tom
fast666
#4 Posted : Monday, October 24, 2022 12:54:38 AM(UTC)
fast666
iam recording on ssd .
my pc specs are
core i7 4790
ddr3 16gb ram
graphics card AMD RX570 4GB
