3 Pages<123>
JAIRODJ
#21 Posted : Saturday, October 23, 2021 5:41:29 AM(UTC)
JAIRODJ
Views messages in topic : 128
Was thanked: 16 time(s) in 12 post(s)
hi, version 1.0.8 has bugs
- does not connect with vmix
- does not close the functions combobox, after selecting the command.
raugert
#22 Posted : Saturday, October 23, 2021 5:46:46 AM(UTC)
raugert
Canada
thanks Jairodj !!
I will remove the update for now until further testing .
regards,
Richard
raugert
#23 Posted : Sunday, October 24, 2021 1:48:50 AM(UTC)
raugert
Canada
Here is a new update.
https://cli.re/vMix-Script-Builder-1.0.9
changelog:
- URLEncoded Script now updates when changing fields
- can now copy selected text from compiled script
- added new commands in vMIx24
thanks 3 users thanked raugert for this useful post.
Joeboe on 10/24/2021(UTC), jet on 10/26/2021(UTC), billh2020 on 11/29/2021(UTC)
chaosmoon
#24 Posted : Wednesday, October 27, 2021 6:24:36 PM(UTC)
chaosmoon
Netherlands
Originally Posted by: raugert Go to Quoted Post
@ chaosmoon
..you can choose to disable the "Enhanced Security" option in the vMix Web settings. This should allow the Dynamic scripts to run again.
This worked, thanks!
lance_05
#25 Posted : Thursday, January 27, 2022 1:04:08 PM(UTC)
lance_05
Philippines
I'm encountering error when using the SetOutput script generated.
It generates the following:
Function=SetOutput4&Input=VIDEO
The one I saw working from the forum is:
Function=SetOutput4&Value=Input&Input=VIDEO
raugert
#26 Posted : Thursday, January 27, 2022 3:08:32 PM(UTC)
raugert
Canada
The "SetOutput4" command requires the word "Input" in the value field when selecting an Input. (see Shortcut chapter in vMix User Guide) https://www.vmix.com/help24/ . You need to include this in the "Value" field of the Script Builder.
lance_05
#27 Posted : Thursday, January 27, 2022 3:25:29 PM(UTC)
lance_05
Philippines
Right...
So in the builder, i need to:
1. Select SetOutput4
2. Leave Input Field as blank
3. Set its Value to INPUT&INPUT=VIDEO
For it to generate the same:
Function=SetOutput4&Value=INPUT&INPUT=VIDEO
I just expected that the builder will automatically re-arrange the fields or disable any field to match the vmix function's syntax.
Anyway, thank you so much for creating this app. This app is a huge help to us who just started using VMIX scripting.
raugert
#28 Posted : Friday, January 28, 2022 2:35:33 AM(UTC)
raugert
Canada
@lance_05
It is a bit confusing at first when using some of the shortcuts :)
The fields required for SetOutput4 in the Script Builder are actually:
1. Command = SetOutput4
2. Input = VIDEO
3. Value = Input (You have a choice of Output, Preview, Multiview, Input) In your case you need to enter the word "Input" as you are directing a specific Input to Output4
thanks 1 user thanked raugert for this useful post.
lance_05 on 1/28/2022(UTC)
raugert
#29 Posted : Sunday, February 6, 2022 1:21:50 AM(UTC)
raugert
Canada
UPDATE: Version 1.0.10
https://cli.re/vMix-Script-Builder-1.0.10
- fixed a bug where the "Input field" was not responding correctly if the "Port" number was changed from the default 8088
MickeyMJJ on 2/8/2022(UTC)
rnhturner
#30 Posted : Sunday, March 13, 2022 4:44:15 AM(UTC)
rnhturner
The following selection should not have a space in it:
SetImage VisibleOn
It works using SetImageVisibleOn
This is showing up for a few of those selections.
raugert
#31 Posted : Sunday, March 13, 2022 6:04:48 AM(UTC)
raugert
Canada
Thanks for the heads up. I’ll look into it.
Richard
raugert
#32 Posted : Tuesday, March 22, 2022 2:14:04 AM(UTC)
raugert
Canada
Update Version 1.0.11
https://cli.re/vMix-Script-Builder-1.0.11
- fixed SetImageVisibleOn
- added new commands for vMix25
eduardocfs on 3/22/2022(UTC)
Joeboe
#33 Posted : Sunday, May 1, 2022 12:45:36 AM(UTC)
Joeboe
Hi all, I am looking for a simple script where, when I play a clip by just clicking they play on the input window, it fades the audio up at about 6 secs., and when I pause it again, it fades it back to '0' at about the same rate
#34 Posted : Sunday, May 1, 2022 2:00:53 AM(UTC)
Check for play/pause state from the API XML of the clip and combine with the setvolumefade function(see shortcuts)
There is a post somewhere in this forum that has lots of scripting examples
raugert
#35 Posted : Tuesday, July 12, 2022 1:57:55 AM(UTC)
raugert
Canada
Update version 1.0.12
https://cli.re/vMix-Script-Builder-1.0.12
- Input field is now editable when using Input numbers rather than Input names.
Ario on 1/6/2023(UTC)
burie
#36 Posted : Friday, October 14, 2022 2:50:32 AM(UTC)
burie
Germany
Hello!
Why does these tool not work with my vMix25 4k Version?
RU
BuRie
raugert
#37 Posted : Friday, October 14, 2022 4:59:06 AM(UTC)
raugert
Canada
Check that you have the Web Controller enabled in vMix settings. I believe it is disabled by default when updating to vMix25.
burie
#38 Posted : Friday, October 14, 2022 9:04:21 PM(UTC)
burie
Germany
Web Controller IS activated
raugert
#39 Posted : Sunday, October 16, 2022 10:11:47 AM(UTC)
raugert
Canada
Please be more specific..
Does the application load ok ?
Are you running the application from the vMix computer or on an another computer on the same network ?
Can you see the input names from vMix in the Script Builder's "Input" dropdown ? If not, it's a network issue. Perhaps wrong IP and Port number ?
burie
#40 Posted : Sunday, October 16, 2022 4:06:58 PM(UTC)
burie
Germany
Does the application load ok ? - Seems ok
It is the vMix machine. The plan is usage with Tablet, but step by step...
Yes, I can See the Inputs and the field names
I am able to create multiple lines of commands, but if I click on "Test Script" nothing happens in my vmix titles
Guest (8)
3 Pages<123>
