3rd Party Software and Development
vMix Script Builder App --Updated 11 July 2022--
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
hi, version 1.0.8 has bugs - does not connect with vmix - does not close the functions combobox, after selecting the command.
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
thanks Jairodj !!
I will remove the update for now until further testing .
regards, Richard
Here is a new update. https://cli.re/vMix-Script-Builder-1.0.9changelog:- URLEncoded Script now updates when changing fields - can now copy selected text from compiled script - added new commands in vMIx24
 3 users thanked raugert for this useful post.
Joined: 2/23/2021(UTC) Posts: 3  Location: Amsterdam Thanks: 2 times
Originally Posted by: raugert  @ chaosmoon ..you can choose to disable the "Enhanced Security" option in the vMix Web settings. This should allow the Dynamic scripts to run again.
This worked, thanks!
Joined: 1/15/2022(UTC) Posts: 7  Location: Manila Thanks: 2 times
I'm encountering error when using the SetOutput script generated.
It generates the following: Function=SetOutput4&Input=VIDEO
The one I saw working from the forum is: Function=SetOutput4&Value=Input&Input=VIDEO
The "SetOutput4" command requires the word "Input" in the value field when selecting an Input. (see Shortcut chapter in vMix User Guide) https://www.vmix.com/help24/ . You need to include this in the "Value" field of the Script Builder.
Originally Posted by: raugert  The "SetOutput4" command requires the word "Input" in the value field when selecting an Input. (see Shortcut chapter in vMix User Guide) https://www.vmix.com/help24/ . You need to include this in the "Value" field of the Script Builder. Right... So in the builder, i need to: 1. Select SetOutput4 2. Leave Input Field as blank 3. Set its Value to INPUT&INPUT=VIDEO For it to generate the same: Function=SetOutput4&Value=INPUT&INPUT=VIDEO I just expected that the builder will automatically re-arrange the fields or disable any field to match the vmix function's syntax. Anyway, thank you so much for creating this app. This app is a huge help to us who just started using VMIX scripting.
@lance_05
It is a bit confusing at first when using some of the shortcuts :)
The fields required for SetOutput4 in the Script Builder are actually:
1. Command = SetOutput4 2. Input = VIDEO 3. Value = Input (You have a choice of Output, Preview, Multiview, Input) In your case you need to enter the word "Input" as you are directing a specific Input to Output4
 1 user thanked raugert for this useful post.
The following selection should not have a space in it: SetImage VisibleOn
It works using SetImageVisibleOn
This is showing up for a few of those selections.
Thanks for the heads up. I’ll look into it.
Richard
Hi all, I am looking for a simple script where, when I play a clip by just clicking they play on the input window, it fades the audio up at about 6 secs., and when I pause it again, it fades it back to '0' at about the same rate
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Joeboe  Hi all, I am looking for a simple script where, when I play a clip by just clicking they play on the input window, it fades the audio up at about 6 secs., and when I pause it again, it fades it back to '0' at about the same rate Check for play/pause state from the API XML of the clip and combine with the setvolumefade function(see shortcuts) There is a post somewhere in this forum that has lots of scripting examples
Joined: 2/18/2019(UTC) Posts: 59  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hello!
Why does these tool not work with my vMix25 4k Version?
RU BuRie
Check that you have the Web Controller enabled in vMix settings. I believe it is disabled by default when updating to vMix25.
Originally Posted by: raugert  Check that you have the Web Controller enabled in vMix settings. I believe it is disabled by default when updating to vMix25. Web Controller IS activated
Originally Posted by: burie  Why does these tool not work with my vMix25 4k Version?
Please be more specific.. Does the application load ok ? Are you running the application from the vMix computer or on an another computer on the same network ? Can you see the input names from vMix in the Script Builder's "Input" dropdown ? If not, it's a network issue. Perhaps wrong IP and Port number ?
Originally Posted by: raugert  Originally Posted by: burie  Why does these tool not work with my vMix25 4k Version?
Please be more specific.. Does the application load ok ? Are you running the application from the vMix computer or on an another computer on the same network ? Can you see the input names from vMix in the Script Builder's "Input" dropdown ? If not, it's a network issue. Perhaps wrong IP and Port number ? Does the application load ok ? - Seems ok It is the vMix machine. The plan is usage with Tablet, but step by step... Yes, I can See the Inputs and the field names I am able to create multiple lines of commands, but if I click on "Test Script" nothing happens in my vmix titles
