Hi, I have got a new Allen & Heath SQ-5 desk and I’m wanting to stream audio. I’ve downloaded all of the drivers and the DAW control (midi control is what they now call it). The laptop recognises it. I’ve set the routing on the desk to match the output on usb 1+2. In voix when I add an audio input, it shows SQ 1+2, 2+3 etc. When they open, it shows audio enabled but there is no visualisation on the right side of the input. It appears in the audio mixer but there is no input. What am I doing wrong?
Thanks for the quick reply. I've installed the ASIO/WDM driver already.
Turns out they have put an option in a setup menu to switch between SQ-Drive and USB B. It is automatically set to SQ-Drive. It needs to be set to USB B.
Thanks for all your suggestions.
