10 Pages<1234>»
richardgatarski
#21 Posted : Tuesday, June 17, 2014 6:31:32 AM(UTC)
richardgatarski
Not sure if this is an (old) bug, or the way it is supposed to be. But when I tried adding a List input in vMix Basic the error given is "The Input Limit in this Edition has been reached". I think it should rather be something like "This Input type is not available in this Edition".
I actually first read "Limit" as "The number of inputs", which confused me as I had no other inputs. Then I checked the Edition comparison table and realized what actually was the problem.
Furthermore, it would be more logical if feature dependent errors were given when the Input is added in the new menu, not when the user after configurations click "OK".
Thanks.
ClementN
#22 Posted : Tuesday, June 17, 2014 7:06:46 AM(UTC)
ClementN
Romania
When I use "solo" button for an audio ( mp3 ) input it is heard in the headphones but also it goes to the "master", too.
Is it the way it was designed ?
My understanding was that "solo" button will only help the monitoring ( headphones ) and not go to the master ..
Later Edit: In fact, the actual sound is not going to the main output or the recording which is ok but the Master indicator shows the solo level.
I was confused by that.
Thank you,
#23 Posted : Tuesday, June 17, 2014 7:08:42 AM(UTC)
hassan yaghi wrote:
martin i have vmix 12 and installed vmix 13 on same pc diffrent forlder, i run vmix 13 sound indicators on vmix 13 move and works fine, but i cant hear any sound on speackes althogh in the audio output i selected my sound card. i close vmix 13 and run vmix 12 every thing works perfect, same cad selected as audio output, it is so weired to me, i tried every thing, i uninstalled both vmix 12 and 13 and reinstall vmix 13, same problem in vmix 13.
Could you please list the exactly name of the device selected in the audio settings? Is it different to Default DirectSound Renderer?
Also, please open up the audio mixer in vMix, click the i button on the Master mixer and send me a screenshot.
Thanks,
#24 Posted : Tuesday, June 17, 2014 7:10:03 AM(UTC)
The solo input will not go to the recording, stream or external output.
It will display audio bars in the Master so you can see the levels of what you are soloing.
nandhitv
#25 Posted : Tuesday, June 17, 2014 9:48:25 AM(UTC)
nandhitv
admin wrote:
* Improved Virtual Sets (UV Map support for talent reflections and accurate video screen mapping)
Demo Video for This UV reflection ?
Thremir
#26 Posted : Tuesday, June 17, 2014 11:32:01 AM(UTC)
Thremir
Found a bug:
Due to the new "Mouse Click Action", when an input is clicked, the "Automatically Mix Audio" kicks in and mutes it when set to preview as it normally would
Other than that, real good job as always!
lbgaus
#27 Posted : Tuesday, June 17, 2014 12:56:36 PM(UTC)
lbgaus
Hi Martin,
The vMix preview is really nice. With the redesign of the audio engine, is it now possible to have the master audio meter and the meters for Inputs show a little more audio resolution, along with a DBFS scale? Something that looks similar to this would be helpful:
Thanks!
madness
#28 Posted : Tuesday, June 17, 2014 8:26:28 PM(UTC)
madness
loaded 13.0.0.90 on my Win7 x64 system tonight, and upon launching, received this message, of which I sent the error report.
https://drive.google.com...bWE5SUk/edit?usp=sharing
Audio Engine could not start. Please ensure a sound device has been installed.
Startup.AM_New
Unsupported bit rate.
This was followed by a vMix has stopped working Windows dialog.
I have the built in Soundmax device, as well as a Alesis Multimix8FX installed and my primary in/output device.
#29 Posted : Tuesday, June 17, 2014 9:36:00 PM(UTC)
Thremir wrote:
Found a bug:
What do you have the action set to? Cut is the equivalent of clicking the cut button for example, which will turn on the audio if auto audio mixing is enabled.
GBIM
#30 Posted : Wednesday, June 18, 2014 3:12:20 AM(UTC)
GBIM
Martin, Can you please do a small demo on how to apply the uv mapping reflection
thanks
Regards
GBIM
richardgatarski
#31 Posted : Wednesday, June 18, 2014 9:20:15 AM(UTC)
richardgatarski
While experimenting with v13 I noticed an audio echo, and a couple of some minor issues.
For both v12.0.131 and v13.0.0.90 I have first set Settings to Default and Closed the Preset. Then set Audio Output to an external line output and Recording Audio to a line input (and for v13 Headphones Output to Null Renderer).
Then added a single Input with video.
Playing the video in v12 I can listen to it in the external mixer (taking in the line out from the PC), sounds good.
Playing the same video in v13 introduce a barely noticeable echo as I listen in the external mixer, suggesting some kind of feedback. If I disconnect the audio cable from the PC's line out and connect it directly to the headphone (bypassing the external mixer), same echo. Still echo if I listen in the external mixer and physically remove the audio cable from the externl mixer's Main out to the PC's line input connector. In other words, the echo does not come from using an external mixer.
A few side notes.
In the audio mixer for v12, when the recorder is started, there appears a "MP4" module (if recording to mp4).
In the audio mixer for v13 there is alwas a "Recorder" module, even when not recording.
For v13 (have not tried this in v12) if I click "Default" in Settings I am asked to specify Frame rate and Size. If I set something (PAL, 1280x720), immediately exit, and start vMix again, I am asked for the same thing again. This time, again setting PAL, 1280x720, exiting and restarting, I don't have to specify Frame rate and size.
#32 Posted : Wednesday, June 18, 2014 10:07:32 AM(UTC)
Set the Headphones output to the same as Audio Output.
vMix will see that they are the same and disable one automatically, setting it to Null Renderer just causes vMix to fallback to the default
audio which may cause duplicate outputs to be heard.
madness
#33 Posted : Wednesday, June 18, 2014 10:48:39 AM(UTC)
madness
Startup.AM_New
I take it I am the only one to experience this so far???
It appears to work alright on another win7x64 system I have tried.
Not sure what I can do to make it work on my production system.
nandhitv
#34 Posted : Wednesday, June 18, 2014 11:01:36 AM(UTC)
nandhitv
richardgatarski
#35 Posted : Wednesday, June 18, 2014 11:21:40 AM(UTC)
richardgatarski
vMix will see that they are the same and disable one automatically, setting it to Null Renderer just causes vMix to fallback to the default audio which may cause duplicate outputs to be heard.
Thanks, that was the problem. Suggest a warning notice when Audio Output is changed.
BTW, setting Audio Output is one of those changes that requires a restart. So I suggest again that those settings are marked and/or warned for in the settings window.
#36 Posted : Wednesday, June 18, 2014 12:32:07 PM(UTC)
It looks like the bit rate in settings was set to 32bit on that computer which doesn't work in vMix 13 at the moment.
I'll fix this in the next update, but in the mean time you can track down the config file and delete it or update it manually.
(It is in c:\users\username\AppData\Local\StudioCoast_Pty_Ltd\vmix64.exe*\13.0.0.90\user.config)
Thremir
#37 Posted : Wednesday, June 18, 2014 12:37:38 PM(UTC)
Thremir
admin wrote:
Thremir wrote:
Found a bug:
I think it's kind of hard to explain, so I just made a quick video for it:
http://youtu.be/y_SCCjEG3TM
Cheers,
Håvard
#38 Posted : Wednesday, June 18, 2014 1:09:58 PM(UTC)
@ Thremir
I think this is by design.
As long as you a have "Automatically Mix Audio" selected, it will behave this way.
If it is un-checked, audio will remain active or live.
madness
#39 Posted : Wednesday, June 18, 2014 6:44:37 PM(UTC)
madness
Thanks Martin!
Deleted it, and re-launched, Came up with the same error that wen closed, was followed by another vMix error.... Object reference not set to an instance of an object. Unhandled. and disappears within a couple seconds.
gregboy12
#40 Posted : Thursday, June 19, 2014 9:26:54 AM(UTC)
gregboy12
Any chance v13 can recognise Elgato Game Capture capture card please guys that would be amazing as i have read loads of people on different sites saying they would buy if it excepted more capture cards like this as xsplit recognises it and stuff
Similar Topics
vMix 13 preview Shortcut key issue (General Discussion)
by IceStream 6/18/2014 7:05:42 PM(UTC)
10 Pages<1234>»
