Joined: 3/20/2020(UTC) Posts: 32  Location: Oregon Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
The change in behavior for closing VMix is frustrating. Before it would just prompt to close, now it prompts to Save or Discard. It would be great if there was an option to change to the previous behavior, this way people that like the new behavior can keep it if they want. My templates are now getting overwritten because users/volunteers think something bad will happen if they choose the big red button. People are trained to save or lose something generally speaking. So when someone starts up VMix, there is more verification than before for its use in case something changed.
 1 user thanked mikesg for this useful post.
Rank:: Advanced Member
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
Because everything is stored in the XML of the .vmix file, even the tiniest change triggers the "are you sure?" dialogue box. For example, if your save has a clock in it, the time is saved in the file so when the time changes (which it always does every second), it asks.
the ndi of microsoft teams there aaren't separate !!!!
if i have 2 ndi of teams... audio ndi1 is on ndi1 and ndi2....audio ndi2 is on ndi1 and ndi2... all mixed
Originally Posted by: formatta2003  the ndi of microsoft teams there aaren't separate !!!!
if i have 2 ndi of teams... audio ndi1 is on ndi1 and ndi2....audio ndi2 is on ndi1 and ndi2... all mixed Sir, this is a Wendy's. 😅 From MS support site: "Each individual user will have a stream available over NDI®. The incoming audio for a meeting is mixed together and will be the same for all individual user streams." https://support.microsof...vidual%20user%20streams.
Originally Posted by: jpetrie  Originally Posted by: formatta2003  the ndi of microsoft teams there aaren't separate !!!!
if i have 2 ndi of teams... audio ndi1 is on ndi1 and ndi2....audio ndi2 is on ndi1 and ndi2... all mixed Sir, this is a Wendy's. 😅 From MS support site: "Each individual user will have a stream available over NDI®. The incoming audio for a meeting is mixed together and will be the same for all individual user streams." https://support.microsof...vidual%20user%20streams. thank you but is it new? until a few weeks ago ... the audio channels were all separate ..... and on some social channels I read that with vmix version 24 they still work separately!
I recommend you ask Microsoft, sorry!
I have noticed memory leaking. I have a project with a single SRT input with a passphrase.
I have observed the same problem on different computers and different SRT sources.
Joined: 1/23/2020(UTC) Posts: 2  Location: Oklahoma Was thanked: 2 time(s) in 1 post(s)
Originally Posted by: mikesg  The change in behavior for closing VMix is frustrating. Before it would just prompt to close, now it prompts to Save or Discard. It would be great if there was an option to change to the previous behavior, this way people that like the new behavior can keep it if they want. My templates are now getting overwritten because users/volunteers think something bad will happen if they choose the big red button. People are trained to save or lose something generally speaking. So when someone starts up VMix, there is more verification than before for its use in case something changed. I feel this is a very annoying feature that should allow the user to switch it off. We use vMix for a house of worship application. We make minor changes to the preset nearly every time we use the software, but we do not want them saved. We have multiple people using the software and would prefer that this not show up on exiting the software. I have spent hours trying to determine what had been changed when someone saves the current settings at the end of the service.
 2 users thanked Millpaub for this useful post.
Joined: 8/26/2020(UTC) Posts: 1  Location: California
Originally Posted by: CHILEvents  Is the Countdown to time Timer able to trigger the OnCountDownCompleted Trigger. It seems not.. Is this intentional?
I just found this to be an issue still. Not really sure how to make it work the way I want it to.
Joined: 8/2/2021(UTC) Posts: 12  Location: Utrecht Thanks: 2 times Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: jonathonc  Originally Posted by: CHILEvents  Is the Countdown to time Timer able to trigger the OnCountDownCompleted Trigger. It seems not.. Is this intentional?
I just found this to be an issue still. Not really sure how to make it work the way I want it to. You could try a workaround with a script containing: Define a countdown time SetCountdown StartCountdown Sleep (Same lenght as countdown) -- Do Something else. If you'd like to change countdown times around during production, you could store this in a dynamic value and use this in the script aswell. Then trigger the script with a shortcut.
 1 user thanked QuintvK for this useful post.
