Shortcut to to push a graphic up the screen to a set position
Hi Guys
Does anyone know if / how I can create a shortcut to have a GT title / input move horizontally up the screen to a set position?
I've tried using SetPanY but this just moves the graphic immediately, whereas I want it to animate up the screen.
Thanks in advance!
Joined: 12/27/2012(UTC) Posts: 5,515  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks in advance! depending on exact movement whishes might be achievable within your title design itself (not enough info in the question) else move/pan in steps using scripting.
Thanks for the quick reply - I simply need the graphic to move Y from 0 to 0.17 within half a second.
I couldn't find any animation options in the GT designer to achieve this?
Originally Posted by: Daniel H  Thanks for the quick reply - I simply need the graphic to move Y from 0 to 0.17 within half a second.
I couldn't find any animation options in the GT designer to achieve this? again a lot depends on the title itself , does it already contains animations for example ? does it really needs to happen at a certain time( button press or delay) or on overlayin for example Personally i would opt for a script if it has to be on command . might have to calculate the steps to match the movement within the distance and time wanted btw panY is vertical
