Daniel H
#1 Posted : Thursday, March 24, 2022 10:36:48 AM(UTC)
Daniel H
Hi Guys
Does anyone know if / how I can create a shortcut to have a GT title / input move horizontally up the screen to a set position?
I've tried using SetPanY but this just moves the graphic immediately, whereas I want it to animate up the screen.
Thanks in advance!
#2 Posted : Thursday, March 24, 2022 10:42:22 AM(UTC)
Originally Posted by: Daniel H Go to Quoted Post
Hi Guys
Thanks in advance!
depending on exact movement whishes might be achievable within your title design itself (not enough info in the question)
else move/pan in steps using scripting.
Daniel H
#3 Posted : Thursday, March 24, 2022 10:45:50 AM(UTC)
Daniel H
Thanks for the quick reply - I simply need the graphic to move Y from 0 to 0.17 within half a second.
I couldn't find any animation options in the GT designer to achieve this?
#4 Posted : Thursday, March 24, 2022 10:50:50 AM(UTC)
again a lot depends on the title itself , does it already contains animations for example ? does it really needs to happen at a certain time( button press or delay) or on overlayin for example
Personally i would opt for a script if it has to be on command . might have to calculate the steps to match the movement within the distance and time wanted
btw panY is vertical
