lamish
#1 Posted : Tuesday, May 26, 2020 5:16:27 PM(UTC)
lamish
Sweden
Im new to the vMix community.
I just installed the software and i try to add my inputs.
I got two video capture cards.
1. DeckLink 8K PRO
2. DeckLink SDI 4K
When i add the input from the DeckLink SDI 4K it works perfekt.
But when i try to add either one of the 4 inputs from DeckLink 8K PRO i get the following error:
"8KPROSDxx. Resolution has an invalid token."
I also attached a picture showing the Error se below.
Is there someone that has experienced the same problem and know what to do?
SeanEmer
#2 Posted : Tuesday, November 10, 2020 6:15:28 AM(UTC)
SeanEmer
I have encountered this same issue! I discovered that it is due to renaming the SDI connectors in Desktop Video Setup. Delete the custom labels you've made for the connectors and then vMix will accept them again. This does not seem to happen when renaming the connectors on a Decklink Duo 2. In that case everything works even with renamed connectors. Only the 8K Pro seems to have this problem on our setup. Very annoying that it doesn't just work correctly.
thanks 2 users thanked SeanEmer for this useful post.
daniel514 on 12/9/2020(UTC), PosLanNik on 2/1/2021(UTC)
SeanEmer
#3 Posted : Thursday, March 10, 2022 8:43:11 AM(UTC)
SeanEmer
Quick update here. I discovered that I only get the invalid token error if the custom label from Desktop Video Setup starts with a number. Calling it "8K SDI1" throws that error in vmix. Calling it "DL8K SDI1" allows everything to work as expected. Weird!
thanks 1 user thanked SeanEmer for this useful post.
stevespaw on 3/11/2022(UTC)
Similar Topics
RTX 5080 & DeckLink 8K Pro G2 (chatgpt research) (Systems)
by clipads 11/2/2025 5:31:46 AM(UTC)
Can I get help with Decklink 8k Pro and MacM4 Here? (General Discussion)
by pedalquickly 8/25/2025 8:02:49 AM(UTC)
DeckLink 8K Pro G2 key & fill support (Hardware Compatibility)
by 3xscreen 7/3/2025 5:36:27 PM(UTC)
BM DeckLink 8K Pro G2 (Hardware Compatibility)
by s0wndman 10/22/2024 7:48:35 AM(UTC)
Alpha Key and Fill through Decklink 8K Pro (General Discussion)
by JxM 2/26/2023 1:27:09 AM(UTC)
PC with GPU + 2 Decklink 8K Pro (Hardware Compatibility)
by mikavellini 7/1/2022 3:51:04 AM(UTC)
External Thunderbolt PCIe enclosure with Decklink 8K Pro (Hardware Compatibility)
by JxM 11/18/2021 3:06:15 AM(UTC)
Will BM Decklink 8K Pro give us 4 x UHD 60fps in- and/or outputs in vMix? (Hardware Compatibility)
by ProSonas 10/17/2021 8:57:49 PM(UTC)
Decklink 8k Pro - Broken or User Error? (Hardware Compatibility)
by fatty 3/11/2021 7:31:09 AM(UTC)
blackmagic decklink 8k pro "stop" error (Hardware Compatibility)
by WSVR 4/21/2020 6:31:15 PM(UTC)
BMD DeckLink 8K Pro lockups (Hardware Compatibility)
by JohnnyFlash 11/16/2019 7:09:08 AM(UTC)
BMD Decklink 8k pro (Hardware Compatibility)
by MeanTime69 5/27/2019 11:05:18 AM(UTC)
Blackmagic Design - DeckLink 8K Pro / DeckLink Quad HDMI Recorder (General Discussion)
by desmar 3/6/2019 9:51:26 AM(UTC)
