7 Pages«<4567>
richardgatarski
#101 Posted : Thursday, February 24, 2022 12:57:00 AM(UTC)
richardgatarski
Originally Posted by: RichDanby Go to Quoted Post
Originally Posted by: Salvatore Go to Quoted Post
If i change the Input name, i can't rename it to the original name.
(for example: Add Input Mix2 - Change Name to MixB - Rename it to Mix2)
That is the same in v24. If you delete the name it will revert back to the original text.
Well, I still think it should be possible to change back to the original name. That deleting means reverting is awkward, illogical, and not documented. My two eurocents ;)
#102 Posted : Thursday, February 24, 2022 4:12:49 PM(UTC)
Was thanked: 4744 time(s) in 1630 post(s)
vMix 25 Preview Update Released (25.0.0.21)
* New Output input for 4K, Pro and Max which routes the Program feed for use as another input.
This can be used to show a picture in picture of the Program when sending a different output to callers for example.
* Fix for Mark In button staying red if opting to use a -X time button instead after.
* vMix will now internally check for any preset changes on closing.
This means if the preset has not changed, it will only warn about closing and will not prompt to save.
* vMix can no longer be closed while Recording, Stream or MultiCorder is running, regardless of if the padlock feature is in use.
thanks 19 users thanked admin for this useful post.
mgrayeb on 2/24/2022(UTC), Peter1000 on 2/24/2022(UTC), Chircanu on 2/24/2022(UTC), doggy on 2/24/2022(UTC), DC Mike on 2/24/2022(UTC), eduardocfs on 2/24/2022(UTC), stigaard on 2/25/2022(UTC), Reinaldo on 2/25/2022(UTC), nikosman88 on 2/25/2022(UTC), ask on 2/25/2022(UTC), RichDanby on 2/25/2022(UTC), ron2210 on 2/25/2022(UTC), joel72004 on 2/26/2022(UTC), jet on 2/26/2022(UTC), NeObr on 2/27/2022(UTC), avsoundguy on 3/1/2022(UTC), raugert on 3/2/2022(UTC), sinc747 on 3/3/2022(UTC), jpetrie on 3/10/2022(UTC)
Salvatore
#103 Posted : Friday, February 25, 2022 8:17:41 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
New Output input freeze after adding a second New Output input and close the vMix Error "A maximum of 1 Output inputs can be added at a time."
richardgatarski
#104 Posted : Friday, February 25, 2022 11:29:52 PM(UTC)
richardgatarski
The new Output input is by itself worth an update to v25 :)
A very warm welcome and huge thanks to the vMix team!
Freezes for me too.
The limitation (no documentation yet in the Help, quess it will come) of one Output input can easily be overcome by adding Virtual inputs of the output Input. Of course that means a, for some of us annoying, "Virtual - " in a bunch of Input's. But I can live with that (or maybe future versions will be able to omit the "Virtual").
(Sidenote: asking for Change an Input to an Output would be too much, so I'll refrain from that and do it manually instead :D )
RichDanby
#105 Posted : Saturday, February 26, 2022 4:38:44 AM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
Totally agree!
I'm not sure if only having a single Output Input will work for me but I'm sure it will make lots of peoples' setups a lot less 'hacky', and that should make them more reliable.
For me, I bring in "vMix Video" twice for different purposes and use the delay under the input's advanced tab of one to create a safety delay (motorsport where bad crashes can't be shown on the stream). I can't do that with virtual inputs (and that delay is disabled on the output input anyway). It feels like a Video Delay input should work but I had problems in the past making it stay exactly X seconds delayed and in sync with an audio input delayed by X000ms. I'll have to do more experimenting.
But, to save this post, one minor bug report -
In a Video Delay input the list of categories to save a clip to includes 'Search'. It also includes the 16 new categories even if they are disabled (though adding a clip to a disabled category shows up in the category when it is enabled.)
jet
#106 Posted : Saturday, February 26, 2022 7:15:15 PM(UTC)
jet
Was thanked: 39 time(s) in 37 post(s)
This is nice and can be used example for final output color correction.
However it would be nice if overlays would always be unaffected to the color correction effects applied to this "Output input".
..and there should be a prevention mechanism that would prevent output "Output input" directly back to output.
xaver
#107 Posted : Sunday, February 27, 2022 3:57:32 AM(UTC)
xaver
Rank:: Advanced Member
I think something is also to the operator
'irony on'
who prevents you to shut down your system or plug off the power
'irony off'
avsoundguy
#108 Posted : Tuesday, March 1, 2022 9:37:49 AM(UTC)
avsoundguy
COMMENT: I noticed when using the change color feature in Title Editor that gradients can not be changed (more complex operation I'm guessing) only when a solid fill color is chosen. Changing colors when gradients are chosen would be pretty nice if possible.
#109 Posted : Tuesday, March 1, 2022 3:46:58 PM(UTC)
vMix 25 Preview Update Released (25.0.0.22)
* Documentation up to date.
* Fix for Output input freezing when attempting to add more than one.
* Disabled non-functioning buttons on Output input such as Loop and Audio
* Video Delay save dropdown now only showing active categories.
* Fix for preset filename in save confirmation not displaying.
* Default codec for Video Delay and AVI now changed to vMix Video Codec instead of MJPG.
This is considered a release candidate, with the final public release due soon.
If you have a bug report, or believe your bug report was missed, please post it here.
Thanks,
thanks 7 users thanked admin for this useful post.
jet on 3/1/2022(UTC), eduardocfs on 3/1/2022(UTC), Roi on 3/1/2022(UTC), raugert on 3/2/2022(UTC), stigaard on 3/2/2022(UTC), sinc747 on 3/3/2022(UTC), avsoundguy on 3/3/2022(UTC)
jet
#110 Posted : Tuesday, March 1, 2022 5:33:58 PM(UTC)
jet
'irony on'
'irony off'
OK, so lets remove all the existing safety mecanisms from vMix so perfect operators like you can shine more ;)
STADIORADIO
#111 Posted : Tuesday, March 1, 2022 7:04:23 PM(UTC)
STADIORADIO
vMix 25 Preview Update Released (25.0.0.17)
* All title colors now default back to hidden, to match previous functionality of the Hidden data checkbox.
Colors were made an exception for convenience, however after further consideration and feedback from customers, this has been reversed.
If you wish to edit colors of a particular object in vMix, you will first need to manually turn off the Hidden checkbox in the Data tab of GT Designer.
* Fixed title color text not being compatible with HTML colors due to the order of the alpha channel in GT.
This has now been corrected and any colors that do not have any transparency will now also display as a standard six digit color (#000000)
* Title colors now show in XML API alongside Text and Image objects.
* Title colors now work within the Title Editor presets feature.
I can't understand where to intervene :-(. I have a problem displaying the Twitter logo on "Social 10- Bricks Red.gtzip". It's white on white and I wanted to change the color of the rectangle where the Twitter logo appears, otherwise I don't it shows.
#112 Posted : Tuesday, March 1, 2022 7:20:15 PM(UTC)
In GT title designer
Screenshot 2022-03-01 101833.png (31kb) downloaded 2 time(s).
STADIORADIO on 3/1/2022(UTC)
STADIORADIO
#113 Posted : Tuesday, March 1, 2022 7:48:50 PM(UTC)
STADIORADIO
Thank you. Very kind
Roi
#114 Posted : Tuesday, March 1, 2022 11:40:18 PM(UTC)
Roi
Philippines
I experienced a yellow indicator on my live stream after I updated my vMix to 25.0.0.22. UPDATE 22.png (2kb) downloaded 3 time(s).
imaago
#115 Posted : Wednesday, March 2, 2022 6:42:12 AM(UTC)
imaago
Switzerland
I have the problem that loading the preset takes a very long time (about 3-5 minutes) when one of the NDI PTZoptics camera is not turned on and therefore cannot be reached.
Addition:
If the cameras were not registered with the NDI Access Manager, then it goes fast.
Xotic
#116 Posted : Wednesday, March 2, 2022 9:04:00 AM(UTC)
Xotic
Can text color also be controlled via a data source? Considering text color is also able to be manually changed in vMix title editor, it would be great to have the option to databind to control the color from a remote source like a spreadsheet.
#117 Posted : Wednesday, March 2, 2022 12:55:44 PM(UTC)
This is not related to the recent update, see below or contact us via our web site for further support:
https://www.vmix.com/kno...mes-show-orange-or-amber
Roi on 3/2/2022(UTC)
#118 Posted : Wednesday, March 2, 2022 12:56:41 PM(UTC)
Unfortunately not much we can do about this, vMix will be attempting to connect to the camera and eventually timeout. Make sure all sources are live before opening a preset.
Or open the preset via the Open button then untick that particular input in the selection window.
gpdipalmerahtimur
#119 Posted : Wednesday, March 2, 2022 7:38:42 PM(UTC)
gpdipalmerahtimur
Indonesia
Hi Martin,
There is a change in PHOTOS Input that I noticed:
vMix 24
Screenshot 2022-03-02 163552.png (188kb) downloaded 1 time(s).
vMix 25
Screenshot 2022-03-02 163249.png (185kb) downloaded 0 time(s).
Why did PHOTOS lose Transparency support? I think it is a good feature. Furthermore, I did see Black Border option, but can't figure out why we need black border on black background? Should we just keep the old behavior of PHOTOS?
Please be kindly advise.
Thanks in advance.
#120 Posted : Wednesday, March 2, 2022 7:50:56 PM(UTC)
Originally Posted by: gpdipalmerahtimur Go to Quoted Post
Hi Martin,
Thanks in advance.
I don't see a difference here between v24 and v25
Noticed you are not using the same picture though
Guest (7)
7 Pages«<4567>
