HWL1223
#1 Posted : Monday, March 20, 2017 11:06:02 AM(UTC)
HWL1223
turned on a machine that was working FINE 2 days ago. vMix 18.0.0.65 on a current Windows 10 Pro.
IF I load my default (last preset) and stream, its fine.
IF I load my default and stream and then record, its fine.
IF I load vMix and go to the Record gear to change the Record params, vMix crashes. Every time. even with no preset (even if I change formats).
IF I use the last vMix record config, it records fine, BUT then it will not stream.
What is up with this? Job tomorrow morning, of course.
Thanks.
#2 Posted : Monday, March 20, 2017 11:17:08 AM(UTC)
HWL1223 on 3/20/2017(UTC)
HWL1223
#3 Posted : Monday, March 20, 2017 11:38:02 AM(UTC)
HWL1223
Holy Crap!
did not see that notice - that fixed it....I would like to figure out when MS does an update so I can delete the supplement file.
What is with MS??? Seems no matter how I safety myself, MS can figure out a way to circumvent my cautions. And screw OneDrive too while Im at it.
Thanks again.
