another slight panic of a different sort - Crashes.
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
turned on a machine that was working FINE 2 days ago. vMix 18.0.0.65 on a current Windows 10 Pro.
IF I load my default (last preset) and stream, its fine. IF I load my default and stream and then record, its fine.
IF I load vMix and go to the Record gear to change the Record params, vMix crashes. Every time. even with no preset (even if I change formats). IF I use the last vMix record config, it records fine, BUT then it will not stream.
What is up with this? Job tomorrow morning, of course.
Thanks.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
Holy Crap! did not see that notice - that fixed it....I would like to figure out when MS does an update so I can delete the supplement file.
What is with MS??? Seems no matter how I safety myself, MS can figure out a way to circumvent my cautions. And screw OneDrive too while Im at it.
Thanks again.
