Eliot Hochberg
#1 Posted : Saturday, February 18, 2017 11:49:22 PM(UTC)
Eliot Hochberg
Hi!
I have my build up and running, now I'm seeing things up. Trying to use the output function on the Blackmagic Quad 2 Duo to get an SD signal to some legacy equipment, hitting a wall. Searching hasn't provided an answer.
I have tried many settings in the external renderer, and I have the channels set to shatter in the Quad's setup tool. But I can't figure out which combinations of settings will work.
Any help?
Mathijs
#2 Posted : Sunday, February 19, 2017 10:57:37 AM(UTC)
Mathijs
What setting is vMix running on and what do you try to output?
Normally, when the framerate matches, the set resolution is no problem.
Eliot Hochberg
#3 Posted : Tuesday, February 21, 2017 7:05:40 PM(UTC)
Eliot Hochberg
My system is running 1080i59.94.
I go into the settings on external, and have tried numerous different settings for 59.94:
1080
720x480
854x480
Then, in the Blackmagic video device software, I think I've tried all the combinations, from converting HD to SD, to not doing that. But maybe I missed one.
I've selected the SDI output on the BM from within vmix, and I'm using port 8.
