Configuring output on Quad 2 Duo to SD
Joined: 1/25/2017(UTC) Posts: 39 Location: Los Angeles
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Hi!
I have my build up and running, now I'm seeing things up. Trying to use the output function on the Blackmagic Quad 2 Duo to get an SD signal to some legacy equipment, hitting a wall. Searching hasn't provided an answer.
I have tried many settings in the external renderer, and I have the channels set to shatter in the Quad's setup tool. But I can't figure out which combinations of settings will work.
Any help?
Thanks: 16 times Was thanked: 81 time(s) in 72 post(s)
What setting is vMix running on and what do you try to output? Normally, when the framerate matches, the set resolution is no problem.
My system is running 1080i59.94.
I go into the settings on external, and have tried numerous different settings for 59.94:
1080 720x480 854x480
Then, in the Blackmagic video device software, I think I've tried all the combinations, from converting HD to SD, to not doing that. But maybe I missed one.
I've selected the SDI output on the BM from within vmix, and I'm using port 8.
