  Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
                I want to make a soundboard using the List feature, now it works fine but I have to manually change the list item every time by double clicking on the specific item from the list before clicking on the shortcut, I can only transition to have the shortcut play a specific item from the list, and that doesn't help me, instead I need it to overlayin. So please have that feature in your next update if possible.
  thanks Basel
 Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
                Hi Basel
  not sure I understand exactly what you're trying to do but API has commands to select inputs in lists MoveInput NextItem PreviousItem
  Also there are commands to overlay any inputs
  And finally maybe you can try to add your list inputs to a multiview input which is a powerful way to overlay anything anytime with SetMultiViewOverlay
  Sorry if I misunderstood. Hope this helps. Guillaume
