Basel
#1 Posted : Friday, February 17, 2017 10:19:39 AM(UTC)
Basel
I want to make a soundboard using the List feature, now it works fine but I have to manually change the list item every time by double clicking on the specific item from the list before clicking on the shortcut, I can only transition to have the shortcut play a specific item from the list, and that doesn't help me, instead I need it to overlayin. So please have that feature in your next update if possible.
thanks
Basel
#2 Posted: : Friday, February 17, 2017 10:31:09 AM(UTC)
Hi Basel
not sure I understand exactly what you're trying to do but API has commands to select inputs in lists
MoveInput
NextItem
PreviousItem
Also there are commands to overlay any inputs
And finally maybe you can try to add your list inputs to a multiview input which is a powerful way to overlay anything anytime with SetMultiViewOverlay
Sorry if I misunderstood. Hope this helps.
Guillaume
