Hall3008
#1 Posted : Thursday, February 16, 2017 7:08:16 AM(UTC)
Hall3008
Croatia
i have one situation and i wish that you can help me. So i have PC with vMIX installed, and i have ubuntu server (same local network). Is it possible to send singal from vMix to ubuntu server, and from there to create RTMP stream? Ubuntu server have static IP adress. I was trying to stream RTMP directly from VMix but without sucess.
Mathijs
#2 Posted : Thursday, February 16, 2017 10:14:19 AM(UTC)
Mathijs
Streaming RTMP directly from vMix should be no problem at all, that is what we do all the time.
So please let's find out why that is not working for you before making things more complicated than they should be.
If you really need to go to the server first, NGINX with RTMP plugin would be a good way to go.
What is the problem? Is the network not allowing RTMP port usage?
#3 Posted : Thursday, February 16, 2017 12:42:29 PM(UTC)
Hi
for RTMP streaming you need 2 things:
- a RTMP encoder. vMix does that
- and a RTMP server which receives the stream to multiple purposes.
Ubuntu Server is not pre-installed with a RTMP server, so it can't work until you install such a package. As Mathijs said, one solution is Nginx web server with RTMP plugin (which might cause conflict with Apache web server if it is already installed), but there are other options like Mist Server (https://mistserver.org/) or the most reputated one which is Wowza (https://www.wowza.com/) that you can try for free. (Also Red5 or Nimble, etc...)
However, it is not clear to me what you want to do. You say "from there to create RTMP stream"... What for ? Distribute this stream over your local network ? Over the internet ? Please tell us more...
Guillaume
Similar Topics
RTMP stream network buffer delay (Feature Requests)
by RedSevens 11/27/2024 5:51:42 PM(UTC)
Can I delay frames on a RTMP stream? (General Discussion)
by NicholsUNR 4/24/2024 7:01:16 AM(UTC)
RTMP stream as a source input? (General Discussion)
by RandyOK 9/20/2023 2:38:40 AM(UTC)
The new RTMP streaming feature of Telegram (General Discussion)
by TenSob_ 3/13/2022 5:37:11 PM(UTC)
Is there a way to Measure delay of RTMP stream? (General Discussion)
by sean.norris 10/2/2021 2:04:13 AM(UTC)
Dynamic usage of RTSP or RTMP streams (General Discussion)
by gre2gor 4/28/2020 2:05:43 PM(UTC)
NDI to RTMP Stream (General Discussion)
by ralston 2/10/2020 2:41:15 AM(UTC)
Problem with too low bitrate in vmix rtmp streams (General Discussion)
by T68 1/2/2020 7:52:39 PM(UTC)
RTMP stream help (General Discussion)
Belarus Peter1000 6/11/2019 5:37:15 PM(UTC)
Saving a Scheduled Facebook Live Custom RTMP Stream Profile (General Discussion)
by mgrayeb 8/24/2018 6:12:09 PM(UTC)
RTMP streams establish connection the first time only. (General Discussion)
by Paulie 4/11/2017 7:50:00 PM(UTC)
Method to reset rtmp streams from web controller (Feature Requests)
by djevo1 5/12/2016 6:33:19 PM(UTC)
RTMP Streams choppy/lagging (General Discussion)
by Prizefighter 2/27/2016 7:01:27 PM(UTC)
RTMP stream problem with libfaac codec (General Discussion)
by palco5 1/16/2016 12:58:14 PM(UTC)
RTMP stream earth Tv not working (General Discussion)
by zenon 1/15/2016 4:51:34 PM(UTC)
Small Bug with RTMP streams. (General Discussion)
by kgoodyer 7/26/2015 1:00:26 AM(UTC)
Rtmp Streaming to vMix (General Discussion)
by MatthewEarley 7/14/2015 11:59:52 PM(UTC)
Still RTMP stream input have noaudio (General Discussion)
by pilgrims1 1/21/2015 1:02:13 PM(UTC)
RTMP Stream stutter (General Discussion)
by MrRoper 2/27/2014 5:28:27 AM(UTC)
RTMP stream no auto resume (General Discussion)
by dotinga00 1/14/2014 4:51:54 AM(UTC)
RTMP stream capture (General Discussion)
by TVIason 11/7/2013 8:51:12 AM(UTC)
Live Streaming with multiple RTMP streams (Feature Requests)
by jdrwor 7/26/2013 6:25:27 PM(UTC)
vmix and rtmp streaming using ffmpeg (Feature Requests)
by Guest 4/11/2013 8:31:23 PM(UTC)
RTMP STREAM ENCODER (General Discussion)
by zadark 10/14/2012 9:14:43 AM(UTC)
RTMP Streams with Video Delay (General Discussion)
by Grimble 8/9/2012 6:57:11 AM(UTC)
Live RTMP Stream (General Discussion)
by Ferrari 3/25/2012 3:23:28 PM(UTC)
vMix neeed Support to RTMP Stream in a futures editions (General Discussion)
by zadark 12/19/2011 7:17:50 AM(UTC)
re-stream rtmp stream (General Discussion)
by dundurs 10/1/2011 4:50:10 AM(UTC)
